It is currently Sun Sep 14, 2025 12:16 pm
PostPosted: Fri Nov 16, 2007 11:43 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
Hi i'm wonder what north american woods would be fine for fingerboards and bridges. I would like to use all north american woods for a build I have planed. I'm going to use white oak for the back and sides. Redwood for the top and walnut for binding and accents. A friend suggested walnut for the bridge and fingerboard but I don't believe they are hard enough. Any suggestions. Thanks ...Mike
PostPosted: Fri Nov 16, 2007 11:54 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Ovation used Walnut for bridges for years!
Like all other species these are variations in density .
Maple is a great choice for trim and a bridge-just stain it if you do not like the color!
Then there are many others -check with local saw mills!
It'unfortunate that we are pulled toward dark colored woods !
Tradition should actually teach us that we should use what's available and make the best of it !
Old School Violin & Lute makers did !
Mike Collins
PostPosted: Fri Nov 16, 2007 11:58 am
Al Carruth knows of some native species that can be used for this stuff, and I think one of them is Persimmon, which is a relative of ebony. There are others besides walnut that may make great bridges. We've discussed here that Black Locust has very similar sonic properties to Brazilian Rosewood, as does Osage Orange, and those may make for great bridges as well. They would probably both work for fretboards too.
PostPosted: Fri Nov 16, 2007 12:22 pm
I don't know Elmer, one minute you're cracking jokes about wood choices, and now you're giving a serious answer. You don't seem quite like yourself today. See you at the next NEL meeting.
PostPosted: Sat Nov 17, 2007 1:12 am
First name: Jim
Last Name: Kirby
Elmer - Persimmon is more than a close relative, it IS an ebony (same genus).
Do all ebonies grow persimmons? (Fruit that is). The Wikipedia article seems to imply it's so.
Jim Kirby
kirby@udel.edu
PostPosted: Mon Nov 19, 2007 2:50 am
   There are a few woods that will work that are native to the states. Mesquite is hard and dense. Hornbeam will also so the job.
    You want a wood that is hard and stable. Hornbeam is also known as iron woods in my area. It was used for bolts on farm equipment. Apple may also work as should beech.
john hall
PostPosted: Mon Nov 19, 2007 3:43 am
Like John said Mesquite!!! Very very stable. Easy to find stock
PostPosted: Mon Nov 19, 2007 4:17 am
I would think that black locust might work.
Ken Franklin
clumsy yet persistent
PostPosted: Mon Nov 19, 2007 4:18 am
My favorite so far is soft shell almond wood that a student picked up in a fire wood pile in California. It's harder than the hard shell almond wood, looks like cherry, but brown, and works like ebony.
There's a good reason for using dark woods for the fingerboard; white woods show the dirt. I like to stain a light f'board with a tea made by boiling black walnut hulls in water. You can get maple to the same color as walnut.
