It is currently Sun Sep 14, 2025 3:18 pm
PostPosted: Mon Nov 26, 2007 12:53 pm
hey, does anyone know where i can get plans to make a scarf joint cutting jig?? i was watching a video where a guy used a jig to cut a scarf joint on a table saw. it made it seem very easy to do. or if anyone knows of an easier way that would be great. thanks to anyone who can help. brandon.
PostPosted: Mon Nov 26, 2007 1:00 pm
Take a look here on Kathy Matsushita's website. She has a great jig for cutting the scarf joint along with a bunch of other great stuff. I see there are plans there too.
PostPosted: Mon Nov 26, 2007 1:04 pm
sweet.....thanks.
PostPosted: Mon Nov 26, 2007 1:05 pm
Last Name: Abercrombie
What sort of tools do you have?
It only takes a little while to rough-cut it (handsaw, bandsaw) and then use a hand plane (and a square) to true up the gluing surfaces.
I did see pics of a jig for this- not sure you really need plans- search for 'scarf jig' here in the forum archives and you'll find what you need- the topic title was 'Scarf joint cut and join problem'
PostPosted: Mon Nov 26, 2007 1:06 pm
Oops- Rod types (and thinks?) faster than I do.
PostPosted: Mon Nov 26, 2007 1:10 pm
First name: Jim
Last Name: Kirby
Once you get used to it, freestyle on the band saw and a little planing and you are set to go. That's all I do with mine now, after about 9 of them.
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Mon Nov 26, 2007 1:40 pm
What's the problem with designing your own jig and drawing up your own plans?   This is basic stuff, and if you understand how tools work, the jig(s) become kind of self-evident.
PostPosted: Mon Nov 26, 2007 6:46 pm
I made a simple jig to use with my drop saw. I can change the angle and I clamp the neck blank to it to do a cut. Much safer than a table saw. I had a pic and can't find it but you can work it out if you have a drop saw.
Dom
PostPosted: Mon Nov 26, 2007 7:34 pm
First name: Kirby
Bandsaw and plane, have used the disc on my cheap jet lathe to level quickly.
"It's a Tone Faerie thing"
PostPosted: Tue Nov 27, 2007 7:02 am
At the risk of revealing my ignorance... why haven't I ever heard of anybody using a compound mitre saw to cut the neck scarf joint?Unless I'm missing something it seems the easiest way.
I use mine quite a bit (in furniture making) ,with a smooth cutting blade and get good results.
J.R.
PostPosted: Tue Nov 27, 2007 7:09 am
I think Dom did - drop saw / chop saw / miter saw?
PostPosted: Tue Nov 27, 2007 8:08 am
I find a scarf joint one of the easyest joints to do it only takes me 10
minutes to cut free hand with a jap pull saw and then true up by hand.
I think it would take me longer setting up a jig than it would for me to cut it
by hand.
But thats just me and i only make a small amount of guitars.
If i was making 40 a year i would no doubt jig up to the full but in the mean
time my good old japanesse pullsaw serves me well.
Joel.
PostPosted: Tue Nov 27, 2007 9:56 am
Mark it, cut it, ~ 5 minutes
PostPosted: Tue Nov 27, 2007 2:52 pm
Waddy,
Thanks, I'll have to put a thesaurus on my Christmas list!
J.R.
PostPosted: Tue Nov 27, 2007 3:23 pm
Better get an Aussie one.  Drop Saw probably won't be there.  Watch, now, he'll chime in again, and I'll be wrong.
