It is currently Sun Sep 14, 2025 12:20 pm
PostPosted: Sun Dec 02, 2007 6:50 am
I'm looking for some 2.5 inch wide by .010 thick and 20" long spring steel
sheets.... anyone know of a source?
PostPosted: Sun Dec 02, 2007 7:11 am
Stew Mac sells these measuring around 4"-5" X 30" as support for bending on a hot iron............easy enough  to trim down.
PostPosted: Sun Dec 02, 2007 9:59 am
You should be able to find it at any industrial supply house.
Here.
I believe it's cheaper through Grainger, but these folks have a place right
over in La Crosse. I don't know if you'll be able to find real high carbon
spring steel in a 2.5" width, but if some simple rolled shim stock will do I
think you'll have a lot more options.
PostPosted: Sun Dec 02, 2007 10:00 am
McMaster-Carr has this stuff but you may have to buy some quantity. I just got a .005 x 6" x 15' sheet from them for bending sides.
PostPosted: Sun Dec 02, 2007 3:08 pm
duh shoulda guessed... McMaster has everything.. and they do have .010 2.5
width spring steel..... Thanks Shane.
