It is currently Fri Jul 18, 2025 10:26 am
PostPosted: Mon Dec 03, 2007 10:22 am
where do you get the stuff?
PostPosted: Mon Dec 03, 2007 10:24 am
www.veneersupplies.com
PostPosted: Mon Dec 03, 2007 1:30 pm
Highland Hardware too.  Here
PostPosted: Mon Dec 03, 2007 1:31 pm
Pumping up my numbers!
PostPosted: Tue Dec 04, 2007 3:18 am
How is it used for bending? (soak time, spray, immersion etc....
Is there an issue with finish and adhesives?
PostPosted: Tue Dec 04, 2007 4:00 am
1) Spray
2) Wait minimum of 2 hours
3) Bend normally
No finish or adhesive issues after 4 guitars
PostPosted: Tue Dec 04, 2007 4:19 am
Interesting, JJ.  Others have recommended spraying, wrapping in Kraft paper, letting dry for a couple of days, then bending with normal process.  I like your idea better.
Here is another question.  I have a set of sides for my current builld, Zebrawood, that have cupped.  I have sprayed the, inside side of the cup with water, and re-stickered, but they seem not to be flattening out completely, even after two applications of water.  Would it work to spray them with Super-Soft II, flatten them out, then thickness, then bend?  Would I have to use SS again, or just wet and bend?  I'll be using a bending iron.
PostPosted: Tue Dec 04, 2007 5:46 am
You want the Glycol to be absorbed into the wood fiber thoroughly. This takes longer than a couple hours on a back and side set. You want the wood to dry to avoid chemical staining. A couple hours may work well with thin veneers but on a side set that is .08-.095 thick it will take much longer.
I spray wrap in kraft paper/rotate daily and bend on the third day.
JJ you are likely getting some aid from the SSII in just 2 hours but my experience is that Three days is more effective.
PostPosted: Tue Dec 04, 2007 6:17 am
I think I've posted my routine so many times on this forum that I just got lazy and gave the Cliff's Notes version.
I typically have waited overnight but have also found it to be effective within a few hours as long as it has absorbed. Some woods take longer...but if you feel better with 3 days, go for it.
Yes...I wrap in kraft paper and lightly spray the outside of the wrap with distilled water before bending normally.
This isn't rocket science!
PostPosted: Tue Dec 04, 2007 6:51 am
Uri Geller don't need no stinkin Supersoft to bend sides........
PostPosted: Tue Dec 04, 2007 7:32 am
I must say allthough products that make our life easyer are wonderfull
imho
the idea of spraying chemicals on to my wood makes me a little uneasy.
I thought that the introduction of the heat blanket made my life easyer
now i find there is another product for me to spend my hard erned cash
on
I havent tried this product so i am no position to poo poo it and for
dificult to bend timbers like paduak or brittle and expensive timber like
zirocote it sure seems like a wonderfull product but i for will think twice
before using any chemicals on easy to bend woods like mahogany (for
example)That i have no truoble bending by hand let alone with a blanket.
saying that i will buy a tub for my tricky woods as i am sure it will save
me money on possable broken sides.
Oh yes the reason i started writing, has anyone experienced buckling of
the sides once bent after using supersoft 2.
Joel.
PostPosted: Tue Dec 04, 2007 7:57 am
The only place I use it is on high figure or hard to bend woods. those are the most prone to warp/cup, which is what I think you mean by buckle. i have had no problems as that is a sign of access moisture not the ply-ability of the wood fiber. The heat from bending cooks out all excess moisture in my routine.
PostPosted: Tue Dec 04, 2007 8:28 am
Thanks michael,
I will give it a go next time i am using a dificult timeber in the mean time i
will stick to my current method.
Joel.
PostPosted: Tue Dec 04, 2007 8:29 am
Timeber thats a whopper of of a misspell even for my dyslexic brian
Wheres that edit button when you need it.
joel
PostPosted: Tue Dec 04, 2007 10:30 am
Waddy - you need to wet the convex side. Then sticker, weight and wait. Works most every time, except when it doesn't.
                Peace, Paul
PostPosted: Tue Dec 04, 2007 12:02 pm
Bob C told me just the opposite.  Interesting.  I'll try anything, though.
Hi Paul.  Haven't seen you lately.
PostPosted: Tue Dec 04, 2007 4:05 pm
I bent some figured maple sides to a sharp cutaway form using SSII and it worked beautifully. I  let it dry overnight before bending, then moistened the wood before bending. I could almost bend it to shape without the form. no cracks, splits or any other damage found.
