It is currently Tue Jul 29, 2025 11:16 am
PostPosted: Wed Jul 13, 2005 11:03 pm
Can LMI's SPBSRJ Bridge saddle routing jig be modified to use a Porter Cable 7310 Lam Trimmer?
I like the jig, but its set up to be used with a dremel - Poo!
PostPosted: Wed Jul 13, 2005 11:09 pm
i had a look at the photo in the cattle dog and it seems it would be a very simple operation to move the guide to accept a lam trimmer if necessary.
also easy to build your own.crazymanmichael38547.369224537
PostPosted: Wed Jul 13, 2005 11:48 pm
I actually drilled new holes in the base plate attachment to fit my lam trimmer. they were just out of the way enough to work. if you cant do that then make up another one out of some rosewood or plexi if you have it.
Matt
