It is currently Fri Jul 18, 2025 10:12 pm
PostPosted: Wed Jan 09, 2008 12:12 am
I was approached by ASIA to write another article. What would you people like to hear about. I have a case of writers block and am looking for inspiration .
   ASIA is in need of support and I hope we all can help
PostPosted: Wed Jan 09, 2008 12:17 am
A tutorial on how you make your nice molds would be good. I don't think it would impact sales either.
What are the differences in making one mold verses going into production?
Someone told me that you were the source of many of the things the Martin's Luthier's connection sells. If that is true, an article on how that came about might be interesting.
PostPosted: Wed Jan 09, 2008 1:16 am
John, I think an article on side bending may be good.
From the thickness, profiling and bending, heat, duration etc, for various types of wood.
PostPosted: Wed Jan 09, 2008 1:31 am
A good hard look at side bending would be a good one John! Addressing issues like how to avoid cupping and breaking as well as wood preparation would be good issues to cover.
PostPosted: Wed Jan 09, 2008 2:02 am
I would like to see a fast foolproof way of fitting necks to the body.
PostPosted: Wed Jan 09, 2008 2:14 am
John, I think there are some good suggestions with side bending. Although I haven't had issues (yet!) I do remember how nervous I was bending my first side. That was even magnified 10 fold when bending my first cut away. You might actually make it about bending in general? I see a lot of questions on bending bindings and purflings. Details that I've personally found found value in reading about here on OLF and around would be:
Side thickness, Temperatures, moisture, cut away considerations, figured woods, wrapping (kraft paper,foil, etc), bending form materials (spring steel, st. steel, etc), Super Soft (might need to not endorse a product and call it a "bending agent" typical to use in veneers?), spring back, cupping, double sides, side bracing. That certainly looks like a LOT to cover in an article?
I think that an article similar to Hesh's recent neck setting technique would also be good. I'm certainly refining my technique after seeing it.
Good Luck! If there's anything I can do personally to help just PM me. I could certainly proof read if you need someone to do that.
Joe
PostPosted: Wed Jan 09, 2008 2:21 am
     I just sent in an instruction manual for ASIA to print but I do think a more detailed article will be a great idea and will do one.
     I will see that these ideas come together and will hopefully get them up in the next few issues. Rememeber that you can also send in articles.
I'll second the neck fitting idea...but the side bending idea is also excellent, especially if you include the cutaway information. Other ideas might be:
Bridge Making
Neck Making (or some variation)
Installing amplification systems in acoustics
Neck resets
Installing rosettes
Builing a Vac Press jig (always a hot topic)
PostPosted: Wed Jan 09, 2008 2:49 am
Write an article on why we need, or don't need, two luthier's associations.
Really.
PostPosted: Wed Jan 09, 2008 3:03 am
I think an article on bending would be good too.
Especially cutaways!
PostPosted: Wed Jan 09, 2008 3:15 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
How about a guide to online luthier resources?
http://www.PeakeGuitars.com
PostPosted: Wed Jan 09, 2008 3:48 am
As for GAL and ASIA I like and belong to both. There are more than 1 ways to do things. Both organizations have merit and both provide a service.
   It is an interesting idea. You can write one Mario , I am sure they would be interested
john
PostPosted: Wed Jan 09, 2008 4:44 am
I like the idea of an artical on not so much how to build fixtures but more on concept and design process of various fixture designers. That way you can incluid input from various fixture designers. This could be more of interspective into the thought processes that whent into the designs of the various fixture designers, rather than of a how to.
PostPosted: Wed Jan 09, 2008 9:58 am
Last Name: Garrish
[QUOTE=grumpy] Write an article on why we need, or don't need, two luthier's associations. Really.
Double the annual conventions! And confusion, too!
If you write it, I'll buy the issue it's in. And the following one, for the letters section.
Bob Garrish
PostPosted: Wed Jan 09, 2008 11:21 am
First name: Jim Howell
John--
You are getting great suggestions!  I'd like to add one more, and that is a tutorial based around your inlaying prowess.  Something with your die grinder in action.
I belong to both ASIA and GAL and support both willingly.  If one organization is good, two have to be better!
Jim Howell
Charlotte, NC
PostPosted: Wed Jan 09, 2008 2:29 pm
   thanks again I have alot of ideas to work on . The Bending is a great article and I will do a detailed article on that.
PostPosted: Wed Jan 09, 2008 2:41 pm
Personally, I really like there being two organizations. GAL is much more west coast oriented and ASIA mid west to east coast. It is so much easier for me to get to ASIA symposium. I guess for a recluse like Grumpy, getting to either is a moot point
John a detailed article on bending would be great!
PostPosted: Wed Jan 09, 2008 3:42 pm
The reason for two luthiers' organizations are steeped in a lot of turmoil, and I personally would love to see a reconciliation and merging of the GAL and ASIA.   Unfortunately it will probably take the death of a generation before that can happen.   Too much bad blood shed in that schism...
PostPosted: Wed Jan 09, 2008 3:45 pm
And John, I think you should take a good look at the Doolin-style side bender design.   There's a lot to be said for being able to very precisely profile sides and then register them at the butt before bending.   You just can't do that with the Fox style benders.   Also, working with lights on the inside and a heating blanket on the outside really works well.
Users browsing this forum: Bing [Bot] and 14 guests
