It is currently Tue Sep 16, 2025 10:29 am
PostPosted: Fri Feb 22, 2008 3:46 pm
I tried a bolt-on mortice & tenon neck on my last archtop (after getting some good pointers from Mark Blanchard) and was very happy with the results. A tutorial was suggested, so here it is based on my current project.
I used 1/4-20 KD bolts & barrel nuts, as I felt they would be more forgiving to the angles involved than fixed inserts. After a spirited debate (not here) about whether or not to glue the extension, I decided not to. The extension contacts the top only as far back as the mortice (no glue), and from there back is totally cantilevered.
Two things you'll need are a 24" long (short flute) bit, and a long shopmade allen wrench. (.300" mild steel bar, cross-drilled for a handle at one end & end drilled for a stub of the correct allen wrench at the other- epoxied in)
The first step is to properly fit the partially shaped neck, re centerline / height at bridge / etc., so it's perfect before proceeding.
Milton, ON
PostPosted: Fri Feb 22, 2008 3:52 pm
......and tighten her up!
Hope this helps.
Milton, ON
PostPosted: Fri Feb 22, 2008 3:57 pm
Awesome Dave to get this tutorial. I am doing an archtop next, after my current OM is well along, so this is timely.
So, no glue anywhere in the joint?
PostPosted: Fri Feb 22, 2008 9:41 pm
I also bolt on my archtop necks. I use threaded inserts and it is really a pain to get everything lined up properly. Dave's method looks easier and possibly stronger to me.
I don't use any glue... not needed.
Mark
PostPosted: Sat Feb 23, 2008 11:22 am
Thanks Mark, and thanks for your help.
I should mention that I graphite reinforce right into most of the extension, which I think becomes more important, given it's not glued.
Milton, ON
PostPosted: Sat Feb 23, 2008 3:02 pm
I run carbon bars up into the extension as well. I think that helps keep the neck extension straight whether the joint is glued or not.
Mark
PostPosted: Sat Feb 23, 2008 4:37 pm
Dave,
Thanks for the tutorial. It's always nice to have a few pictures to make it clear.
PostPosted: Sat Feb 23, 2008 10:55 pm
Dave, thanks for posting this tutorial. Very well done and very much appreciated.
PostPosted: Sun Feb 24, 2008 7:53 am
First name: Nelson
Last Name: Palen
What Anthony said.
Nelson
PostPosted: Sun Feb 24, 2008 8:32 am
Thanks so much for taking the time to create and share the pics and your method. I'm close to beginning the neck work now on a couple archtops and have wanted to try the bolt-on method. Great timing for me!!
Robert
PostPosted: Sun Feb 24, 2008 7:55 pm
Robert, welcome to the OLF. As a hint - we really love pictures...
PostPosted: Mon Feb 25, 2008 7:40 pm
Dave - Many thanks for taking the time to document and post this. I'm planning to move on to archtops soon, once these mandolins are completely done. You couldn't have timed this much better!
Rick Jones
Rochester Hills, MI
http://home.comcast.net/~rajones19
PostPosted: Fri Feb 29, 2008 10:25 am
Does anybody know where to get these barrel nuts with a centered hole? All the ones I've seen the hole is slightly off center. You can still use 'em but it would be a lot better with a centered hole.
PostPosted: Sat Mar 01, 2008 8:15 am
First name: Erik
Last Name: Hauri
State: Maryland
I just sand down the long end of my (Woodcraft) barrel nuts until they're symmetric about the hole; also because the 3/4" barrel nuts always seem to come out at ~0.78" or more when I mic them, so one end is always sticking out the end of a 0.75" tenon.
The member formerly known as erikbojerik....
PostPosted: Sat Mar 01, 2008 10:31 am
If you shop around a bit, you'll find shorter ones. Mine (shown in the first pic) are under 1/2". (I can therefore make the barrel holes blind, which locates them laterally.)
Milton, ON
PostPosted: Wed Sep 28, 2011 10:06 pm
First name: duh
Last Name: Padma
thank you
duh Padma
PostPosted: Wed Sep 28, 2011 11:04 pm
Pretty darn cool.
PostPosted: Wed Aug 07, 2013 5:40 am
First name: Ake
Last Name: Bjornstad
City: Gotheburg
Zip/Postal Code: 41143
Country: Sweden
