It is currently Mon Jul 21, 2025 12:48 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Wed Mar 05, 2008 12:05 pm
Howard, before the days of plastic clamp pads, my father glued leather pads onto his clamps. Might be worth trying to decrease the sliding around. For flat glue jobs, I am a fan of the smaller Bessey parallel jaw "K" clamps, which solve most of the problem.
Brook
PostPosted: Wed Mar 05, 2008 12:17 pm
Howard Klepper wrote:
Best cam clamps I have are Woolson's. The cam design gives more force than any other. Next are Garrett-Wade, then Klemmsia. I tried bargain hunting with Shop Fox from Griz and it was money thrown away; you'd think they could just copy one that works well, but they didn't.
Hey, it OT, but I keep getting frustrated by the crappy swivels on my Bessey sliding bar clamps; they want to walk around when being tightened. Anyone have a way to improve them? They are nice clamps otherwise.
I agree on the Woolson's I have 12 of his in 8", 10" and 12" The last batch he made are my favorites. clamp like a steel trap. and adust clamp pressure in between very well. If anyone is in touch with Paul and he gets a wild hair to make some again let me know
On the Bessey I cut a piece of 5/16 ply 1x1 round the corners and glue cork to one side now epoxy this to swivel pad on the adjusting screw end and glue cork to the other clamping edge of the bar. This worked for me.
PostPosted: Wed Mar 05, 2008 12:29 pm
The problem is not the pad, it's the swivel. Too much friction, doesn't swivel. Turns the pad instead. The pads are crappy, too, but that's not what I was referring to.
PostPosted: Wed Mar 05, 2008 1:14 pm
Chuck
ChuckH wrote:
One question though, how did you mortise the holes for the rods? Drill bit :?:
I used my drill press and a 1/4" bit to set the ends and then used a 3HP plunge router and a 1/4" bit worked pretty well, I'm sure there are other ways.
Peter
PostPosted: Wed Mar 05, 2008 1:25 pm
Guest wrote:
Chuck
Peter
Or build up the body from three laminates with the center laminate a few thousands wider than your bar stock and located to set the depth of the bar slot. Then use the excess of the center laminate to close the notch. This saves having to cut the notch in any form.
PostPosted: Wed Mar 05, 2008 1:51 pm
Paul will be at the Miami show and I intend to go pay him a visit. I'll try to remember to ask him about the clamps.
PostPosted: Wed Mar 05, 2008 8:27 pm
I built my own clamps too. Not hard. I just bought a clamp and copied it. Easy! They work very well. With me, it was kind of a get your feet wet, before you start the real guitar building process.
PostPosted: Thu Mar 06, 2008 10:28 am
well I just bought 38 clamps for $400 from a guy on ebay , he uses the aluminum bars and various hardwoods , cherry, maple etc etc , with leather pads .
less than $11.00 each for the two sizes sounds very reasonable, at that price it is hardly worth it for me to take the time to run around , gather the plans,various materials and equiptment then do the build . I will let you know how well they work when I recieve them .
I have twelve grizzly clamps I will sell cheap , if anybody wants them ( where's the self inflicted, finger down the throat, gagging icon when you need it? ) live and learn ...Jody
PostPosted: Thu Mar 06, 2008 11:54 am
ToddStock wrote:
1/8" kerf works for the Borg 1/8" x 1" aluminum or steel bar. I used fillers per the earlier comment, but the placement of the roll pins is actually the key issue in getting a smoothly functioning clamp (DAMHIKT).
DAMHIKT?
PostPosted: Thu Mar 06, 2008 11:57 am
Don't Ask Me How I Know That (DAMHIKT)
I had to google that one.
Horton, MI
PostPosted: Thu Mar 06, 2008 3:05 pm
There are three sets of clamps on ebay right now. There are enough to glue a "D" size guitar. They are priced at about $2.50 less per piece than you can get them for in quantity discount from any of the suppliers. SEARCH The item # is: 260217656323. TITLE: Cam Clamps Set for Luthier Woodworking 38 clamps, (32) 4-1/2" x 8-1/2" and (6) 7-1/2" x 8-1/2" FREE SHPNG w/ Buy it Now.
If you would like to skip ebay and buy them direct that would be great!
JOHN
PostPosted: Thu Mar 06, 2008 3:32 pm
Those ebay cam clamps are made by a friend of mine in Luray. He is a superb craftman and the clamps are well worth the money. The link is http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260217656323&ru=http://search.ebay.com:80/260217656323_W0QQfviZ1. If you need them now is the time to get them!
Sylvan
http://www.wellsguitars.com
PostPosted: Mon Mar 31, 2008 12:53 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Well, I finally have one cam clamp finished. Put the final touches on it this morning. I did find some maple at Menards.
The dimensions for this one is 3/4" x 1 1/2" with 8" reach. Used 1/8" x 3/4" aluminum bar and 5/16" roll pins.
They were simple to make but just time consuming. I spent most of last evening making these while watching "The Godfather" again. Seems like everytime I make something The Godfather is on the tele. Anyway, I don't think I'll be making too many of these, I'll just buy the next few I need. They were fun to make but don't know if it was worth it as was discussed earlier in this thread. I have about 8 bucks in this one clamp.
Users browsing this forum: DennisK and 26 guests
