It is currently Mon Sep 15, 2025 12:47 pm
PostPosted: Wed Sep 05, 2007 11:15 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
Here's some other stuff that I've run on the CNC...these are traditional turkey box calls, as used for hunting. These actually function similar to a violin. The top is rotated across the sides of the box and it "catches" and "releases" the side just as a bow does on the violin strings. If you make them well, they will create extremely obnoxious noises.
These calls below are made with brazilian rosewood bases with mahogany sides and tops...with mahogany inlay on the bottoms.
http://www.PeakeGuitars.com
PostPosted: Tue Mar 11, 2008 6:31 am
Here is a hunting knife I made on the cnc mill and the wire EDM machine at my work.
________________
Jeremy Vonk
PostPosted: Tue Mar 11, 2008 11:45 am
Nice looking stuff !
PostPosted: Tue Mar 11, 2008 12:14 pm
Here's a longboard prototype I did last year and a planetary gear modification for a Black&Decker cordless screwdriver to up the RPM for string winding.
PostPosted: Tue Mar 11, 2008 3:07 pm
Cool stuff all!
Sheldon, I like that little gear...how well did it work out for you?
PostPosted: Wed Mar 12, 2008 9:57 am
Don Williams wrote:
Cool stuff all!
It worked quite well. It took the RPM up to the 1K region IIRC. Not a lot of torque at that speed, but enough to get your strings to pitch. The battery eventually died and I replaced it with a Rigid 12V screw driver.
