It is currently Fri Jul 18, 2025 7:38 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
PostPosted: Fri Apr 11, 2008 2:30 pm
Michael Jin wrote:
MichaelP wrote:
There is no good comparison Foredom SR far better tool, at least IMO More HP. More RPM, More versitle, no runout. built to last
Wow.. that thing looks pretty hardcore. :shock:
Definitely looks like it'd be a little easier to use, though... or a bit more manageable I should say.
The things about it is it has more HP and RPM than Dremel It has a much better chucking system, the bearing housings in both the hand pieces and the motor are much better than Dremel’s. They have great bearing life and pretty much no bearing run out which is the Dremel’s biggest issues in my book. It is also nice to have your hand free to work the router base or hand piece and have the I/O and RPM control at your foots command. These are by all means profession grade rotary tools. The SR can be had for around $190 if you shop Ebay and the Stewmac hand piece if you use the Stewmac inlay router base or the any base designed for the Dremel for about $72 but well worth it.
By the way the Stewmac hand piece is the only hand piece with ¾”-12 un exterior threads. (same as the threads as on the Dremel spindle. And that is the only thing that makes the Stewmac hand piece special.
PostPosted: Fri Apr 11, 2008 2:39 pm
Hesh wrote:
Yeah Michael can also offer and do dental work for his customers..... :D
So we both can off a form of health care now laughing6-hehe laughing6-hehe
PostPosted: Fri Apr 11, 2008 3:06 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I don't think I am going to reply to this.
PostPosted: Fri Apr 11, 2008 5:41 pm
I agree it has more muscle but only runs 18000 rpm, the Dremel 300 series will crank 35000 so for small diameter bits in some cases the dremel could be a better choice,
Keith MacKenzie
"To err is human to really screw up you need tools"
PostPosted: Fri Apr 11, 2008 6:07 pm
Last Name: Lembo
I still use my dremel for a bit of inlay (until I find a good deal on a foredom), as well as the aforementioned yard implement sharpening.
Another option for a base if anyone is thinking about a foredom (or dremel for that matter...) is the base manufactured by Bishop Cochran (http://www.bishopcochran.com/). I have one of his laminate trimmer bases. Absolutely fantastic.
Anthony
Anthony J. Lembo
Lembo Custom Guitars - www.Lemboguitars.com
PostPosted: Fri Apr 11, 2008 6:21 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
A dust collector, mostly. I leave the case on a shelf and pretty soon its covered in dust. Works very well.
Actually, its my brother's. It I had my own then I could justify buying all the cool stuff for it that makes it a less effective dust collector.
http://redrivercanoe.ca/
PostPosted: Fri Apr 11, 2008 6:38 pm
I use a little grindstone to take the point off the parrot's beack. It's a viscous bird.
PostPosted: Mon Apr 14, 2008 12:01 pm
Anthony Z wrote:
Dremel Multi-Pro 395 (older model). Used for dental surgery, threatening raccoons, paper weight and buffing frets when my Foredom isn't within easy reach.
That's funny AZ, I use this for my dental surgery!
PostPosted: Mon Apr 14, 2008 6:56 pm
Waddy that thing is scary. Does it double as a garage door opener? :D
PostPosted: Tue Apr 15, 2008 12:37 pm
Dremel Multipro (old one), only really gets used with a small sanding drum to fine-tune convex shapes on cut inlay. Die grinder for inlay pockets, laminate trimmer for bigger stuff, routers for even bigger stuff.
PostPosted: Wed Apr 16, 2008 10:47 am
It was actually a Dremel used in Marathon Man for the torture scene, now I have to listen to
horror stories from that movie nearly every day in my office. It was pretty gruesome.
I still use the Dremel and Stew-mac router base for headstock binding but use a laminate trimmer for the rest of my binding channels. I also use the dremel for rosette cutting as Hesh mentioned. I think there are some good uses for it but I find I use it less than I used to, just wish they'd come out with something with really good bearings...
Those cord-driven slow speed handpieces have pretty much vanished in Dentistry, thank goodness. 40 years ago my wife was a Dental assistant and used to get her hair caught it that rotating cord that drove the handpiece. We switched to air rotors pretty much across the board in 1963 or so, things got much better then, except for the noise of the handpiece spinning at 400K rpm. The move is on to electric Dental handpieces now, just not that perfected, the first one I bought got so hot I had to be careful using it. Dumped it in favor of the old tradition air rotors.
Much more information that you needed, I'm sure.
Best
Bruce
Bruce Herrmann
"What lies behind us and what lies before us are tiny matters compared to what lies within us."
PostPosted: Wed Apr 16, 2008 3:48 pm
Had a dremel about 10 years ago,
Burned out in the first week doing light work.
The replacement lasted a year of occasional use....
Never bought another.
PostPosted: Wed Apr 16, 2008 7:51 pm
BruceHerrmann wrote:
It was actually a Dremel used in Marathon Man for the torture scene....
Bruce
Yeah, but "is it safe"
Sorry Bruce I couldn't resist :D
PostPosted: Wed Apr 16, 2008 8:59 pm
I have about 5 of the dremel tools. One Christmas I got 3 of them as presents...must have been a good sale on them? My favorite is the 395. I have the luxury of leaving my dremels set up for a particular job and permanently mounted in it's fixture. One of them is hung over the work bench and has the flexible extension. I use that one for polishing nuts and hollowing out the undersides of neck heels. The others are used for cutting inlay pockets, cutting the channel in the kerfed linings for inletting the x braces, ect.
I also have the foredom, and as said before, it turns much slower. I use this with some of the larger bits for rough shaping various parts and pieces and also shaping and polishing nuts and saddles. The foot pedal takes a little getting used to.
PostPosted: Wed Apr 16, 2008 9:02 pm
Ken, the foot pedal is one of the features I like best about the Foredom. It gives you just another level of control when cutting an inlay pocket.
Users browsing this forum: Michaeldc and 16 guests
