It is currently Sat Sep 20, 2025 7:28 am
PostPosted: Sun Apr 27, 2008 6:42 pm
Hi all.
I'm interested to know more about catalyzed polyurethan. I searched the forum but nothing came up (not sure I use the search engine correctly though...).
So what is the difference between catalyzed vs standard polyurethan and what are the advantages?
Thanks!
Alain Moisan
(Now building just for fun!)
PostPosted: Sun Apr 27, 2008 8:45 pm
Hi There,
This is a topic which has been covered here numerous times, and if you do a search you will find lots of info on it. Anyway, I will try to point you in the right direction:
-If you really want to know almost all there is about wood finishing, take a look at this book:
http://www.amazon.com/UNDERSTANDING-WOO ... 726&sr=8-2
It is considered by many to be the "bible" on wood finishing...now to your question:
A catalyzed "anything" not just urethane, requires a "catalyst" before it is applied. This is like mixing epoxy with part A and part B, as an example. The catalyst will chemically react with the solution, you spray it, then it will dry. These have the advantage of usually being tougher (although people argue this) than a traditional finish, as well as the time required to cure is usually hours, as compared to days or even months with other finishes. You also need to use the "batch" you create, since if you store it, it will harden (unlike lacquer, where you can store in an air tight container until you use it, since it is an "evaporative" finish).
Now with this said, it is also a "hard" finish to apply, since if you make mistakes, it is usually not forgiving. Most are also TOXIC and VERY dangerous to your health! To use these finishes you would need the proper spray and PROTECTION equipment...
Anyway, I can write a book here, but I figured these will get you started....
-CyborgCNC
http://www.cncguitar.com
https://www.facebook.com/CncGuitar
PostPosted: Sun Apr 27, 2008 8:57 pm
Here you go Alain - this link is to a great thread that we had last year. http://luthiersforum.com/forum/viewtopic.php?f=10102&t=13299&p=188481&hilit=+Poly#p188481
PostPosted: Sun Apr 27, 2008 9:25 pm
Thanks guys.
I don't know what I'm dooing wrong with the forum's search engine, but I can rarely get anything out of it!
I'll need to work on that...
Thanks again!
Alain Moisan
PostPosted: Mon Apr 28, 2008 4:58 am
Alain, I used to have the same problems and I thought the search engine sucked. Then I learned you have to use quotation marks. So it turned out I was the one doing the sucking...
Try 'catalyzed polyurethane'. You should get better hits.
PostPosted: Mon Apr 28, 2008 10:53 am
Thanks Alain!
It does work better with quotes!
Alain Moisan
PostPosted: Mon Apr 28, 2008 11:11 am
That thread was on polyester, not polyurethane.
PostPosted: Mon Apr 28, 2008 11:20 am
Yes, I noticed. Very informative anyway.
There are some mentions of polyurethane though.
Alain Moisan
PostPosted: Mon Apr 28, 2008 11:31 am
Oy...
Decide what you want to use, and study -that-. Don't confuse yourself further....
