It is currently Fri Jul 18, 2025 11:04 am
 Post subject: Butt Wedge removal
PostPosted: Tue Apr 29, 2008 11:38 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I have decided that on my Martin OM, I do not want to use the plastic binding, heel plate, and butt wedge. I have already installed the Butt wedge using Gorilla Glue. I would like to remove it. Ideas?
Will Gorrila Glue loosen with heat?
I bought some nice quilted/curly maple from RC for those applications. (Thanks Bob, they look awsome!)
 Post subject: Re: Butt Wedge removal
PostPosted: Wed Apr 30, 2008 12:12 am
Why not just remove it the way you cut to install it ? If you routed the mortise , just route it out.
Link
Route it out. Make a rub collar template slightly larger than the existing wedge and let the chips fly.
If you've got a template collar set the same template will work for your replacement wedge.
-C
Freeborn Guitars
and home of BeauGuard©
Users browsing this forum: J De Rocher, Kbore and 15 guests
