It is currently Tue Jul 22, 2025 7:34 pm
PostPosted: Thu May 08, 2008 11:47 am
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
I just picked up a Delta Drill Press Model 11-990 yesterday. I bought this on ebay and was a local pick-up - $30. It appears to work well. However, I have a couple of questions:
- I am assuming this will suffice for luthiery (I was eyeballing a Grizzley, but for $30, I figured it was worth the shot)?
- It is very dirty and has some surface rust. Any recommendations for best way to clean up/remove surface rust?
- The table is a little difficult to move up and down - any suggestions for improving this?
- It is missing the chuck - suggestions for places to find a replacement?
Thanks in advance!!
Glenn
PostPosted: Thu May 08, 2008 12:35 pm
Congrats Glenn on a nice score at a GREAT price!!! [:Y:]
PostPosted: Thu May 08, 2008 1:08 pm
First name: Jim Howell
Check out Mcmaster-Carr:
http://www.mcmaster.com/
Jim Howell
Charlotte, NC
PostPosted: Thu May 08, 2008 2:23 pm
Did you mean it was missing the chuck key? What about this?
http://cgi.ebay.com/4-in-1-Chuck-Key-Fo ... dZViewItem
Christian
PostPosted: Thu May 08, 2008 2:48 pm
First name: Glenn
Last Name: LaSalle
Yes, that is what I meant. That looks interesting - I will do an Ebay search to see what else is there.
Glenn
PostPosted: Thu May 08, 2008 3:12 pm
Pretty standard 1/2" chuck, usually. Probably can get one at any local hardware or BORG.
PostPosted: Thu May 08, 2008 6:36 pm
When I lost the chuck key on my drill press, I didn't think much about it until I went to the store. I got to hear a long lecture on how I shouldn't have done that and that they were all different for every manufacturer and how could we possibly be expected to keep all those different chuck keys in stock... It's a bigger chuck, so maybe that's it.
I ended up finding mine, so I didn't worry about it.
It is a good idea to use a chuck key with a spring loaded pin on a drill press though. That way you can't turn it on with the key still in it. (Not that I would have ever done such a thing.)
If you can't find one, you can surely call delta.
Miek
Mike Lindstrom
PostPosted: Thu May 08, 2008 8:07 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Glenn,
looks like a good buy to me. to remove the rust, I use a wire brush (admittedly, I us a cup brush
in a 4" grinder, so it's fast). I've not used "Naval Jelly", or any of the chemical concoctions, maybe
somebody else will chime in on that. For the vertical movement, I'd also wire brush/steel wool the
support shaft, then rub on some paraffin wax, or similar. To keep the table pristine, use one of the
non-oil, non-silicone table protectors available at most woodworking shops.
Gene
PostPosted: Thu May 08, 2008 9:06 pm
First name: Glenn
Last Name: LaSalle
Thanks for all the replies!
I was able to find a Delta replacement chuck key here:
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/delta/11-990
Gotta love the internet - I was able to find schematics, Operating Manual, replacement parts :D
Thanks!
Glenn
