It is currently Fri Sep 19, 2025 2:11 pm
PostPosted: Tue May 20, 2008 10:44 am
I'm looking for a large pattern bit (bearing on the bottom) with a spiral cutter for doing neck profiles. 1-1/2" cutting height minimum. 2" would be better. Yes, a shaper would do it but I don't need one for anything else and don't have room anyway.
Do they exist? Googled for awhile and no luck yet. Is solid carbide too brittle get the required shape?
http://www.chassonguitars.com
PostPosted: Tue May 20, 2008 11:19 am
What shape do you require? What don't you like about hand shaping?
PostPosted: Tue May 20, 2008 1:45 pm
Seems to me that you would have a problem using a pattern bit. The reason I say this is the profile should taper from the heel return radius to the peghead volute intersection. therefore if using a pattern bit on a shaper or router table the wood will continually either have less engagement with the shape of the bit as you get closer to the volute or excess as you get closer to the heel return radius. I personally cant see where a profile pattern bit really would be an efferent means of profiling a neck blank
PostPosted: Tue May 20, 2008 1:46 pm
I'm looking for a straight bit to shape the profile from the heel to the peghead, not the cross section of the neck.
I love hand shaping. I just prefer to get the bulk of the material off with machines and start final shaping with something that's already close. I absolutely love my neck building routine! Fast, precise, easily repeatable if I want, easy to adjust for different players, and a satisfying and appropriate combo of machine and hand work.
PostPosted: Tue May 20, 2008 2:36 pm
Try the 3/4" "supercut" (or something like that name) bit from Jesada.
PostPosted: Tue May 20, 2008 3:29 pm
viewtopic.php?f=10117&t=15991
about 3/4 of the way down you'll find this
http://www.charlesfreeborn.com/neck9.jpg
it's an OCEMCO cutter. try this guy
http://www.patwarner.com/index.html
PostPosted: Tue May 20, 2008 4:51 pm
Sweet!! That's exactly it. bliss
I can't find it on ocemco's site though. Is it called something other than a router bit?
The one on patwarner.com is different but looks fine. What a monster.
Thanks Guest (Charles?)
edit: it wasn't ocemco's site after all, it was http://www.carbide.com/catalog/RBits-co ... ofiles.cfm
Still can't find it.
PostPosted: Tue May 20, 2008 6:31 pm
http://www.carbide.com/catalog/simple-s ... arch=quick
PostPosted: Tue May 20, 2008 6:35 pm
don't know why the link doesn't work. use quick search OCEMCO spiral at carbide.com. it's technically a power plane cutter mounted on an arbor with a bearing.
PostPosted: Tue May 20, 2008 7:04 pm
Great, I think I got it.
Many thanks. I had almost given up looking.
PostPosted: Wed May 21, 2008 12:01 pm
If anyone is interested, the part number for that bit at http://www.carbide.com is OCM-FFT-2126-T
Users browsing this forum: No registered users and 48 guests
