It is currently Fri Jul 18, 2025 1:07 pm
 Post subject: White Haze
PostPosted: Thu May 22, 2008 5:01 pm
Hello all!!
I just completed my first guitar and everything was perfect until...
Within minutes after spraying my 12th and final coat of nitro lacq, a white haze has developed over the majority of the guitar. It has been crystal clear for the first 11 coats and conditions were the same throughout (to my knowledge). Could it be moisture? Will this go away? HELP!!!!!!!!!!!!!!!!!
My sincere thanks and gratitude to all your experts!!
Greg
 Post subject: Re: White Haze
PostPosted: Thu May 22, 2008 5:11 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Sounds like moisture!
Give the guitar a lite spray of thinner to soften the finish & let the moisture excape.
This has worked for me.
Mike Collins
PostPosted: Thu May 22, 2008 5:17 pm
First wait a day. If it's still there spray another final wet coat. That should do it. I'd recommend that you don't spray just thinner; you can easily get runs.
What kind of lacquer and thinner did you use? Was it hardware store thinner?
PostPosted: Thu May 22, 2008 5:35 pm
Yep moisture - the RH was higher on the present final coat.
What Mr. Klepper said. :D
PostPosted: Thu May 22, 2008 7:07 pm
Thanks everyone!! Others please feel free to throw in your $0.02.
The fact this is my first guitar I just used the complete finishing kit that stew mac sells and am following their step-by-step guide to finishing. So I am just using aerosol nitrocellulose lacquer (i.e. no thinning involved and no access to a spray gun). Now what?!?
Thanks again!!
PostPosted: Thu May 22, 2008 8:41 pm
Like Howard said. Wait a day or two. If it's still there you could try wetsanding with some 800 or so. This would require, possibly, depending on your setup, another final coat but the wetsanding and waiting a few days should let the moisture out. I've seen it plenty before getting my shop RH controlled.
I have used retarder and a thin coat of lacquer over the blush before with good results too but sounds like you don't have the spray system. Don't fret though, it shouldn't be too bad to remedy. Just be patient.
Best of luck.
"We might not be big but we sure are slow"
PostPosted: Thu May 22, 2008 8:55 pm
Since you don't have a spray set up -I think Stew Mac sells an aerosol called
blush remover or something. It should work to take out the haze if it doesn't
evaporate in a couple days.
PostPosted: Fri May 23, 2008 2:59 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
Use a small amount of "slow reducer" (approx 5%) mixed with the lacquer. This will slow the dry time enough to prevent blushing. Stew Mac does sell a Blush Eraser, which works great. The results are instant. Just a light spritz usually does the trick
John Ressler
PostPosted: Sat May 24, 2008 7:20 am
Again, thanks for all. It seems like everyone is in agreement but I wanted to update you all and then I'll go from there...
Two full days later, it looks the exact same. I can actually remove the residue by just scraping very lightly with my fingernail. Still moisture? If so it sounds like my best plan now is to buy the blush remover from Stew Mac. Can you all confirm it's still moisture even though it appears to be on the surface, and this is still my best option?
I promise this will be the last time I ask gaah
1,000 Thanks!!!!!
Greg
PostPosted: Sat May 24, 2008 7:25 am
I've done the same thing and the blush remover worked fine, the only other thing I would say is give it a few days to cure afterward before continuing to finish.
Keith MacKenzie
"To err is human to really screw up you need tools"
PostPosted: Sun May 25, 2008 2:36 am
so it's right on the surface? Is it at all fluffy or fibrous, like cotton fiber?
PostPosted: Sun May 25, 2008 5:46 am
Last Name: Collins
City: Argyle
State: New York
Do you think the last coat went on dry?
If you spray to far away the finish can go on dry!
If so-sand that coat off and put a wet coat on
mike
Mike Collins
PostPosted: Sun May 25, 2008 6:16 am
I've had the same thing happen to me. Sand it (until the white is gone) and start anew.
PostPosted: Sun May 25, 2008 7:41 am
Most likely it is blushing. I've battled it plenty in the humid Oklahoma summers. Little retarder in the finish and it's not an issue. Moisture is just getting caught underneath the finish and can't escape. You can also wet sand it, and then re-shoot, but unless you modify your shooting process or shoot when the humidity is lower you'll encounter it again.
PostPosted: Sun May 25, 2008 10:44 am
I'm guessing, since he's shooting from aerosol cans, his solution, has to be one addressed to that process. I can see, however, with aerosol, how a poor surface could happen easily. It is hard to get even distribution from a can.
PostPosted: Mon May 26, 2008 8:09 am
Alright, problem solved. HUGE thanks again to everyone for your help. This truly is a great forum!!! It's existence and your advice is very much appreciated in my time of need.
I ended up just sanding the entire guitar and respraying another coat. Everything is back to crystal clear!!!!!
Any (hidden expert) advice on buffing now? I am planning on using buffing pads on a power drill with the two buffing compounds that came in the Stew Mac finishing kit. Pretty straight forward from here?
Cheers,
Greg
Cheers,
Greg
Users browsing this forum: oval soundhole and 12 guests
