It is currently Fri Jul 18, 2025 3:19 pm
PostPosted: Sun Jun 01, 2008 8:55 am
Just curious. I was wondering if this has been done before, or are there guitars out there already like this? I like the shape of the 000/OM, but the sound of the dreads. I've been thinking about making the depth of the sides similar to a dread, but shaping the top and back to the 000 or similar. Advantages, disadvantages? I welcome any and all opinions. Eat Drink
Brad Tucker
PostPosted: Sun Jun 01, 2008 9:09 am
Brad,
I know diddley about dreads so take this with that background but I thought that a significant part of the dread sound comes from havimg not much of a waist compared to OM's as well as the deeper body. So this part of the dread sound probably wouldn't be present.
PostPosted: Sun Jun 01, 2008 9:18 am
Dave,
Thanks. That's what I'm looking for...things I have not considered, and that is one of them. The dread does have more soundboard area. Maybe one could expect a sound somewhere in between the 2 sizes? Keep 'em coming!
Brad Tucker
PostPosted: Sun Jun 01, 2008 11:04 am
A lot of us build smaller guitars (concert, grand concert, orchestra etc.) with more depth than the Martin paradigm, up to 4.5" at the tail for me. It tends to increase the bass response, of course, but only a D sounds like a D… Personally I loosely designed my A-1 around D dimensions, but with a tighter waist for comfort, I am sure there are others.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sun Jun 01, 2008 12:05 pm
Thanks, guys,
The 0000/Grand Auditorium sounds like what is my line of thinking is, Todd. It's just an idea I have been tossing around. I really appreciate the feedback.
Brad Tucker
PostPosted: Tue Jun 03, 2008 9:09 am
My experience with deep body OM/000 is that after 4.5" the main freq drops dramatically. It helps to increase the sound hole by about a 1/8-3/16 on diameter.
If you want the punchier boom sound of a dread Then you might try building a 16" lb near OM shape that is 21" in length and 4 5/8" major depth.
I have never found a deep body At OM dimensions to be neat the cannon a dread is.
PostPosted: Tue Jun 03, 2008 12:58 pm
These OM/D's are Mario's specialty I think. Alot of people have/are trying this including myself. I'm currently working on a quilted honduran mahogany/carpathian guitar that is loosely based on a Martin OM plan but about 5/16" more body depth and not as tight a waist. I just freehanded my template from an OM plan on one side and folded it over to make a perfect match. Also the soundhole is a bit larger.
The voicing process has made me very excited to be able to hear the finished product soon. I believe it is gonna be a "keeper" for sure. I'll weigh in in a month or two when it is finished. Right now it has the top completed and the sides almost ready to accept the back. Here the back is just laid up there and the dark spot on the headblock is a saw mark:
"We might not be big but we sure are slow"
PostPosted: Tue Jun 03, 2008 1:08 pm
Deeper bodies quickly tend toward boomy bass, lack of balance, and sluggish response. No free lunch to be had here. It also weakens the coupling between top, air, and back, so the drop in resonant frequency is less than you might expect from the volume difference (As Al has often explained). I'd agree that 4-1/2" is about the limit. Even more like 4-3/8".
PostPosted: Tue Jun 03, 2008 3:35 pm
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
All this discussion is fine, but if you want to hear some deep bodied OM's, check out
http://www.mauelguitars.com/audio.htm
The Duane Clark and 3 of the Doug Smith cuts were done on koa/cedar Grand OM's ...different guitars at different venues several years apart. See if you hear what you like and maybe that will help in the decision making process.
Hank Mauel
PostPosted: Wed Jun 04, 2008 6:13 pm
Can I ask actual dimensions for the soundhole please I too am doing my first build an OM style guitar to Kinkheads design and like a bassy guitar so may mod it and use this bracing http://www.stewmac.com/tradesecrets/ts0 ... clk=191731 I want to do all I can to help the little un and easy it's birth by picking your collective brains
Formerly JJH
PostPosted: Wed Jun 04, 2008 6:26 pm
Typical Martin-style OM soundholes are 3 7/8" I think.
Mario Proulx was probably the first to experiment with this. Check out his site. Its very informative.
Best of luck
SR
PostPosted: Wed Jun 04, 2008 6:39 pm
I build a guitar that is very similar to the OM/000, but I use dread sides on it. I call it my "DM" model.
To my ears, it has all of the brilliance of the OM trebles and has the volume of a dread. The only difference between what I build and the OM is that the upper bout is slightly larger. I actually prefer the sound of these over a dread. there is a sound clip of my playing one on my YouTube page at http://www.youtube.com/hodgesguitars if you are interested.
Users browsing this forum: Durero and 18 guests
