It is currently Tue Nov 26, 2024 4:38 pm
PostPosted: Mon Jun 16, 2008 3:37 pm
First name: Ron
Last Name: Y
I hope everyone had a good fathers day.
I'm trying to figure out how to bring my spruce top down a little (about 1mm). I don't want to attempt this with a plane due to lack of skill, and I don't have access to a thickness sander. Can I do this with a rubber sanding block and sandpaper?
Also, according to the MIMF Weissenborn Plans the top is thicknessed to 2.5mm-3mm
I'm shooting for 3mm unless someone tells me otherwise. Are these numbers good for a Spruce top?
As always,Thanks for your help.
Ron M.
PostPosted: Mon Jun 16, 2008 4:06 pm
First name: Ron
Last Name: Y
The title was suppose to read "Hand Sanding".
Ron M.
PostPosted: Mon Jun 16, 2008 4:08 pm
Haven't done any soundboard sanding myself yet (waiting for my first wood order), but if i were to try something like that I'd probably go with a long sanding board.
Frank
PostPosted: Mon Jun 16, 2008 4:14 pm
Hand held cabinet scrapers work pretty well for getting Spruce down evenly.
PostPosted: Mon Jun 16, 2008 4:21 pm
First name: David
Last Name: LaPlante
Sure, a wooden block or one of those rubber ones will work fine. I'd suggest 80 grit, anything coarser tends to loose bits of the abrasive which will get imbedded into the wood.
Use a soft (like one of those big carpenter ones) pencil to make a grid of light hache marks and then sand them off...this will keep the plate evenly thicknessed as you go.
Use a bench brush to sweep the dust away at regular intervals so you can see what you're doing.
PostPosted: Mon Jun 16, 2008 4:59 pm
Or find a cabinet shop in the phone book or from the Internet that is near you and ask them if you can rent time on a thickness sander. Depending on where you are located there may also be an OLFer near you who is happy to help.
PostPosted: Mon Jun 16, 2008 5:10 pm
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
I am thicknessing my first top without a thickness sander as well. I plan to use my hand plane to get in the ballpark, then combo hand sand and cabinet scraper to get to final. I have purchaed a couple of very cheap flawed tops, and have practiced on those first. I am about to start "the real top" any day now.
Glenn
PostPosted: Mon Jun 16, 2008 5:28 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Ron & Glenn;
I use a Low angle plane !
Sharpen well !
These planes will cause less tearout( (ripping of the wood)(if you do not make to heavy a cut)
then jack Planes .
Then follow with a sanding block as David has said -this will eliminate
any plane marks!
Go slow-measure allot!!!! [:Y:]
How do plan to measure your top thickness?
mike
Mike Collins
PostPosted: Mon Jun 16, 2008 5:50 pm
Last Name: Collins
City: Argyle
State: New York
Top thinning has always been the most important part of a new guitar build!
I approach it with much thought for the sound(tone).
And of course the strings(guage) used ;and the size of the box!
Depth-etc...!
The low angle works best for me!
i've tried all kinds of plane over the years!
Mike Collins
PostPosted: Mon Jun 16, 2008 5:59 pm
First name: Glenn
Last Name: LaSalle
I have a circa 1920's Stanley #5 that i just recently added hock blade and chip breaker. I sharpend the blade and the plane cuts through like butter :-). I have a gift card ($50) to Woodcraft. my birthday is today as well, plus woodcraft still has free shipping for Father's day ... I may just get the Festool ROS and do as Todd mentions.
I have a deep throat caliper that I use to measure thickness across the top.
Glenn
PostPosted: Mon Jun 16, 2008 6:27 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
My first top I took down with a belt sander.Not really very difficult.I now use a thickness planer.Also a wagner planer works well for getting close.
James
James W Bolan
Nashville Tennessee
PostPosted: Mon Jun 16, 2008 7:12 pm
First name: Ron
Last Name: Y
Mike Collins wrote:
Ron & Glenn;
Sharpen well !
then jack Planes .
any plane marks!
mike
Thats a good question mike. I may have to buy a digital caliper from Stew Mac.
Todd & Hesh
I'll see If I can get access to a thickness sander first. If not, then I'll take the low tech route.
Todd, what thickness would you bring a spruce top for a Weissenborn Style guitar down to? Thanks to everyone for your help.
PostPosted: Mon Jun 16, 2008 8:43 pm
First name: Glenn
Last Name: LaSalle
ToddStock wrote:
Sharp plane is better than a low angle or standard angle plane. Work 90 degrees across the grain until everything is pretty close to the thickness you want, then sand with ROS.
Hi Todd,
What grit paper do you recommend working with the ROS?
Thx!
Glenn
PostPosted: Mon Jun 16, 2008 11:49 pm
First name: Greg
Last Name: Harrington
80 grit to start, then 120, 150, 220 to finish.
Greg
PostPosted: Tue Jun 17, 2008 7:38 am
First name: Ron
Last Name: Y
Thanks Todd.
Ron M.
PostPosted: Tue Jun 17, 2008 8:20 am
I thickness top/back/sides with a #5 Stanley & sanding block.
PostPosted: Tue Jun 17, 2008 9:08 am
First name: Ron
Last Name: Y
When you guys say "low angle plane" exactly what kind of plane are you referring to, a smoothing plane like a stanley No. 4 or 4-1/2? Thanks.
Ron M.
PostPosted: Tue Jun 17, 2008 9:23 am
Country: Romania
No, the 4 and 4 1/2 are normal angle (45 degrees) planes. The bevel faces down. Low angle planes have the blade at a much lower angle (about 12 degrees) but the bevel faces up. Not sure why low angles were developed, but I imagine for two reasons: the "mechanics" are simpler, and they work better in end-grain? Other than that, you can use them without problems on face grain but with a less aggressive blade bevel.
Build log
PostPosted: Tue Jun 17, 2008 10:36 am
First name: Ron
Last Name: Y
Hi Alex,
Thanks for your reply. Can you give me a Stanley plane example, by indicating a model number.
The only thing that I have that comes close is a Stanley 60-1/2 low angle block plane. Thanks.
Ron M.
PostPosted: Tue Jun 17, 2008 10:45 am
I have a thickness sander. But a well-quartered spruce top is simply a joy to hand-plane to thickness, finishing off with a little ROS action to even things out. I do use the thickness sander to level the rosette, though, because it's just easier and more reliable.
PostPosted: Tue Jun 17, 2008 3:22 pm
First name: Ron
Last Name: Y
Thanks Todd for taking the time to go into detail about low angle planes.
PostPosted: Thu Jun 19, 2008 7:28 pm
Call me crazy, but I used a Black and Decker Mouse sander for my first one. I got it close with a hand plane (a #5 Stanley), then the Mouse, then finished by hand....worked fine to me and less elbow grease that way....
Laurie
PostPosted: Thu Jun 19, 2008 7:29 pm
Laurie
PostPosted: Thu Jun 19, 2008 8:02 pm
First name: Ron
Last Name: Y
Laurie
I don't think that's crazy, I think It's creative. I may buy a ROS and caliper and go at It. Thanks Laurie.
Anyone know of a cheap caliper alternative to the high priced ones that will give accurate measurements?
PostPosted: Sat Jun 21, 2008 2:25 pm
I'm having probs with a mahogany back and have had to result to a cabinet scraper and sander now
Cheers guys these tips'll help
Formerly JJH
Users browsing this forum: No registered users and 57 guests
