It is currently Tue Jul 22, 2025 12:07 am
 Post subject: truss rod questions ?
PostPosted: Sun Jun 22, 2008 6:55 am
On a martin scale , how long should the truss rod be ? and on an inside the box , adjustable rod , where should it end down the neck , near the nut ? I am thinking at the first fret, but it now seems too long . thanks Jody
PostPosted: Sun Jun 22, 2008 6:50 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Great question Jody,
I'd guess each brand of truss rod is a different length, but I also would like input on how far out of the neck block the rod should end. I've seen some guitars where the rod comes through the hole in the UTB.
I know that doesn't answer your question. I'm just trying to bump this to the top.
PostPosted: Sun Jun 22, 2008 7:17 pm
What style of truss rod are you using?
PostPosted: Sun Jun 22, 2008 7:32 pm
well i guess it is a one way , set in a sort of square aluminum tube , with a hex head end ... thanks jody
PostPosted: Sun Jun 22, 2008 10:30 pm
Right - but where did you get it - is it an Allied (new style or old style), LMI, Martin, etc? The length would be helpful to know too.
PostPosted: Sun Jun 22, 2008 11:08 pm
i have a few, not sure where they originated, they all have the actualy adjusting rod inside a square aluminum "tube", two slightly different ones , about 15" not counting the adjusting nut ....they both fit nicely into a martin neck slot.... one has a thin brown film on the top of it ( taped to it now )... the other , the adjusting pin is slightly off center ... jody
PostPosted: Mon Jun 23, 2008 6:22 am
They sounds like Martin rods - good description Jody [:Y:]
I think that John Hall (Blues Creek) uses these and might be a good one to PM.
PostPosted: Mon Jun 23, 2008 7:05 am
o.k. thanks for the help... jody
Users browsing this forum: Bing [Bot] and 12 guests
