It is currently Sun Jul 27, 2025 10:03 pm
PostPosted: Wed Aug 03, 2005 1:00 pm
Check the OLF auction tomorrow for this set of Madagascar Rosewood donated by Brian Hawkins (BeachTonewood)
Thanks Brian!
LanceK38567.9175578704
PostPosted: Wed Aug 03, 2005 10:01 pm
The auction is up and here are a few more images of the offered set!
PostPosted: Thu Aug 04, 2005 5:42 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
All quartersawn?
PostPosted: Fri Aug 05, 2005 12:56 am
Bob,
Not sure, ill let Brian chime in here --
PostPosted: Fri Aug 05, 2005 12:15 pm
Hey Guys,
The sides are Q/S if my fading memory serves me, and the backs.....MRW is a very small tree and it is fairly uncommon to find full Q/S backs. Almost always you will be getting flitch cut 4 pc. backs that have been joined to form two bookmatcked peices.
PostPosted: Sat Aug 06, 2005 10:22 am
Hi Brian
I have been offered some Ziricote, but the boards are not wide enough for backs, do you think the techinue used with the Madagascan of doing a 4 piece back, would be suitable with Ziricote ?
Is it just a question of making the join like you would when joining the two halves ?
PostPosted: Sat Aug 06, 2005 11:04 am
[QUOTE=RussellR] Hi Brian
Is it just a question of making the join like you would when joining the two halves ?[/QUOTE]
Well,
You can but I don't know if it would be the best way to do it. Ziricote is a very brittle wood and when resawing it it can curl and in this case it could give you an "S" shape curl to deal with, it is important to sticker it right away. It might be less hasstle to keep and eye out for a board large enough for your needs. Sometimes I see boards large enough for backs on ebay, just make sure that you ask the seller about any cracks in the wood. This is just my opinion and I only know what I know so if anyone out there doesn't agree please chime in.
PostPosted: Sat Aug 06, 2005 11:06 am
Thanks Brian I was thinking fingerboards for the Ziricote so will stick to my original plan.
Many Thanks
Russell
PostPosted: Sat Aug 06, 2005 11:10 am
I've used narrow ziricote for backs before, and have seen others do it if the grain is nice enough like this one.
PostPosted: Sat Aug 06, 2005 11:12 am
Wow Don that is beautiful and that was made up of four pieces ?
yep...
PostPosted: Sat Aug 06, 2005 11:15 am
On a four piece back do you reinforce each of the jpins or just the center join as normal ?
PostPosted: Sat Aug 06, 2005 11:16 am
That is purrrty Don...did you do that??
PostPosted: Sat Aug 06, 2005 11:33 am
[QUOTE=Brian Hawkins] That is purrrty Don...did you do that??[/QUOTE]
yep...that's mine. And of course, it will crack eventually because it's Mexican Crackwood. The name "Ziricote" is just an alias.
Russell, you don't have to reinforce each joint, but I tend to think it's not a bad idea. I did one guitar of MC (aka ziricote) where I reinforced each joint. It still cracked everywhere else. Just keep a bottle of CA handy when you use the stuff...
Don Williams38570.8583912037
