It is currently Tue Feb 18, 2025 12:09 pm
PostPosted: Fri Jul 18, 2008 9:21 pm
First name: Kris
Last Name: Barnett
Hello all,
I messed up again and want some opinions on how to proceed. I build lattice braced classicals and I generally (almost exclusively) build with cedar. This time I used german spruce. I sanded the top too thin in the end block area and there is a very noticeable blackish mark where the end block is located on the soundboard (you can see the endblock through the top). I have thinned the sounboard to this dimension before with cedar but never had this issue. Kinda weird.
Anyway, I believe I have three options (hopefully more if you guys can come up with them [clap] . I can:
A) do a sunburst. I have never done this before but I have been practicing on some old tops and they look okay. Not such a fan of sunburst though, especially on a classical.
B) Relic the guitar. I have tried this before but it doesn't look very, how would you say, AUTHENTIC [headinwall]. I like the idea a lot, but the process is funky for me.
C) I can use a weird little "violin tie" like in the picture. Kind of unusual, I know, but I am limited on ideas at this point. (any thoughts on pros/cons for the sound of the instrument??)
Any help would be greatly appreciated. Also, if anyone has any "antiquing" secrets they want to disclose I would love to hear them.
Hope everyone is well and I look forward to the advice/opinions.
PostPosted: Fri Jul 18, 2008 9:52 pm
A thought.... how about inlaying a pendaloque. A feature used on some older instruments including this Martin Uke.
Rod
PostPosted: Sat Jul 19, 2008 3:54 am
Country: Romania
The inlay would probably weaken the whole thing too much?
I think the violin style would be more OK than a sunburst or an antique finish. The first simply looks inappropriate for a classical the second will probably look fake. But the violin-tie might could look like an innovative and inspired luthier modern conception, some classical players are drawn to this. I would use a normal shape bridge though. (actual an even narrower than normal one)
Build log
PostPosted: Sat Jul 19, 2008 6:18 am
Another option - pull the top and try again. Not as crazy as it sounds; Ross Gutmeier used to do it often for poor audio performance, but not so much any more (practice makes, if not perfect, then very, very good).
Dan
Dan
http://www.acme-archtops.com
PostPosted: Sat Jul 19, 2008 9:48 am
First name: Jim Howell
Rod--
Welcome to the OLF! I've enjoyed reading your posts on the UMGF for years. Good to have you here also.
Cheers-- Jim
Jim Howell
Charlotte, NC
PostPosted: Sat Jul 19, 2008 9:58 am
Use a darker shellac finish.
Users browsing this forum: No registered users and 71 guests
