It is currently Fri Jul 18, 2025 1:31 am
PostPosted: Thu Jul 31, 2008 7:32 pm
Okay now that I've made my radius sanding dish I had to come up with a way to motorize it and this link shows what I came up with so far.
http://www.mimf.com/cgi-bin/WebX?128@12 ... @.2cb67e99
Video to follow hopefully by this weekend.
PostPosted: Thu Jul 31, 2008 9:07 pm
Chris...very cool idea and setup. What is the RPM of the dish when everything is running?
Brad
Avon, OH
PostPosted: Thu Jul 31, 2008 9:36 pm
Well , even with the router set on the lowest setting it's still pretty fast. If I had to guess I'd say it's probably around 300 rpm. Seems like it might have gotten a little faster with the rollers installed. I just took of about 1/8" off the back rim profile in about 20 seconds with a light touch. I think it needs to be somewhat slower. I might try ordering a 3/4" drive roller with a 1/2" shaft to slow it down. I'm under the assumtion that it should be around 150 rpm. I'm also think that at the present speed I might go to a higher grit of sand paper like 120grit instead of 80grit.
PostPosted: Thu Jul 31, 2008 11:49 pm
Mine turns at about 100RPM which is quite nice using 80 grit.
PostPosted: Fri Aug 01, 2008 5:36 am
Mine works but it's a bit agressive at that speed and it would be easy to over do it. Maybe if I was use to it then it at that rpm. it would seem less risky. I think the slower rpm or higher grit psa would give me more control though which is what I'm after with a balance of speed. I'm going to try out my other router with a HF speed control tonight when I get back from work to see if can be set at a slower rpm too. Does anyone know a source of 120 grit 24" dia. psa.?
PostPosted: Fri Aug 01, 2008 10:02 pm
I think McMaster Carr has what you are looking for.
Brad
Avon, OH
PostPosted: Fri Aug 01, 2008 11:56 pm
Nice idea for the table. Very cool. You would want to go with a smaller diameter shaft to slow it down, though...right?
-j.
-jack handy
PostPosted: Sat Aug 02, 2008 9:01 am
I've put in my Porter Cable router and it works with my speed control that I use with heat blanket. I can start it from a stop. Yes the 1/2" shaft would have slowed it down by one half the rpm as the 1" drive roller.
PostPosted: Sat Aug 02, 2008 11:37 am
http://www.youtube.com/watch?v=cp70792aMeU
Here's the video I put together after work last night. I definately need a new computer, I was up to 5:30 this morning trying to get it edited and had to finish it this morning.
PostPosted: Sat Aug 02, 2008 12:34 pm
Very nice jig Chris [:Y:] Thanks for doing the video.
PostPosted: Sat Aug 02, 2008 12:42 pm
Thanks Dave. Hey, I live in Tampa.
PostPosted: Sat Aug 02, 2008 12:51 pm
Chris...I just watched your videos on You Tube. Very impressive and thanks so much for sharing. The videos that you and Todd have done lately are some of the best tutorials I've seen. [clap] [clap] [clap]
PostPosted: Sat Aug 02, 2008 1:46 pm
Chris, Where abouts in Tampa do you live? We will have to get together
sometime soon. I would really like to see your shop and jigs.
And of course your geetars! :D
Users browsing this forum: meddlingfool and 15 guests
