It is currently Sun Jul 27, 2025 5:38 am
 Post subject: baltic birch tail blocks
PostPosted: Wed Aug 06, 2008 11:32 pm
What are peoples opinions here?
They make sense from a durability point of view, but I'm curious to what the general perception is.
PostPosted: Thu Aug 07, 2008 1:02 am
Doesn't seem to hurt Kevin Ryan's sales...
I don't use them because it's actually pretty expensive stuff, and when I resaw mahogany I quite often have a 'spare' side and various other bits of mahogany (or maple, or whatever) scrap that are too small for much else. Glue those up (have vacuum bag, will travel) and you've got your own ply-that-matches-the-rest-of-the-linings. Not cheaper, per se, but it works for me.
PostPosted: Thu Aug 07, 2008 2:54 am
I use them and they work fine for me.
PostPosted: Thu Aug 07, 2008 8:39 am
How about using it for neck blocks?
PostPosted: Thu Aug 07, 2008 9:19 am
My last sheet of 1/2 BB was about $25. Pretty cheap for about a hundred end blocks.
I think Rick Turner uses it for headblocks but of course he stiffens up the area with flying carbon rod trusses.
PostPosted: Thu Aug 07, 2008 10:08 am
He must have a dickens of a time catchin' them flyin' trusses...
PostPosted: Thu Aug 07, 2008 10:33 am
First name: Tracy
Last Name: Leveque
State: CO
Very funny Don :lol:
I use 1/2" birch ply on my end blocks too. Seems lighter than mahogany and more stable. Never used it for a head block, but I do use a 3/4" thick piece of birch ply that I put on top of my head block so the fretboard rests on this instead of the little flat graft in the upper bout.
PostPosted: Thu Aug 07, 2008 10:38 am
Jim,
I do it...works great with the endpin jacks that all my guitars seem to get now...
Stephen,
I'm trying a BB headblock (glued up to double thickness) on a guitar for myself right now...I'll let you know how it turns out...
PostPosted: Thu Aug 07, 2008 10:49 am
I used one on my latest guitar for the same reason as Todd. I
bought a couple small pieces of birch from Woodcraft that should last a while.
PostPosted: Thu Aug 07, 2008 11:24 am
I tried to edit my last post but was too late .
Anyway,I use a piece of birch ply for under the fingerboard ext.too
for a double mortise and tenon bolt on neck.
PostPosted: Thu Aug 07, 2008 11:27 am
I've used a bunch of baltic birch ply for tail blocks, usually the 3/4" stuff though. I cap the ends with scrap mahogany so that the top and back are gluing to long grain rather than the edge of plywood. I like to do a simple finger joint to join the mahogany to the birch ply, just so it can't split at that location too easily.
PostPosted: Thu Aug 07, 2008 11:30 am
Dave can you show how the fingerboard support is attached to your headblock?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Thu Aug 07, 2008 11:58 am
Ricardo, I just cut the angle to match the tops radius and glued the birch
piece on top of the neck block. This is my 1st fb ext. bolt on by the way so I'm learning as I go.
I have glued the previous fb exts. on
Don, I did the same thing with a thin piece of mahogany on the tail block.
No finger joint though. [headinwall]
PostPosted: Thu Aug 07, 2008 1:05 pm
Tom Humphrey used it for headblocks, and I caught it from him. Makes a split-proof tailblock, if you like those thread-in jacks.
Dan
Dan
http://www.acme-archtops.com
PostPosted: Thu Aug 07, 2008 1:08 pm
This is great stuff guys.
Thanks for the input.
Users browsing this forum: Colin North and 17 guests
