It is currently Mon Jul 28, 2025 8:01 am
PostPosted: Tue Aug 16, 2005 7:42 am
OK I have been trying to post a reply and i keep getting page can not be displayed explorer error message and my post does not show up. What is the deal?
PostPosted: Tue Aug 16, 2005 7:50 am
apparently I can post a new reply but not a reply to a specific reply nor a quot and reply.....Just started about 15 min. ago. Whats up with this?
PostPosted: Tue Aug 16, 2005 7:58 am
Probably ghosts in the machine... maybe it could use a reboot.
This is a reply... so let's see if this one works.
PostPosted: Tue Aug 16, 2005 8:03 am
Looks like you can reply to your own post
PostPosted: Tue Aug 16, 2005 8:17 am
[QUOTE=Brock Poling]
This is a reply... so let's see if this one works.[/QUOTE]
well this is a test of a quoted reply seems to work nowMichaelP38580.7211111111
PostPosted: Wed Aug 17, 2005 5:34 am
I figured this out. You can't fill the subjet line. Okay, notice the subject line above is full and didn't let the e and period to display, because it is full. Now if I try to edit this post I cannot.
Why, because it cannot add the RE: to the line, therefore in the software it kicks out and does not allow an edit.
All you have to do to edit any post you get the rejection notice is remove some of the text from the main header. So if I remove, "I figured this out." from the header it will post about four RE:s before filling it up again and disallowing editing.
Cool Huh?
okay, I attempted an edit and got rejected.
Then I removed this: subjet lin
That gives the software room to add RE: to the line and therefore post.Dickey38581.6130671296
PostPosted: Wed Aug 17, 2005 5:58 am
Cool... Good to know. Thanks Bruce.
