It is currently Fri Jul 18, 2025 9:44 am
PostPosted: Mon Sep 01, 2008 6:45 pm
What types of planes and chisels and anything special about the tip of the chisels as if double beveled or rounded heel or front bent? How about it Hesh, I know you like shaving braces. :P
PostPosted: Mon Sep 01, 2008 7:05 pm
City: Jacksonville
I'll go.....
I use an Ibex plane, small one with a convex bottom, and Lee Valley 1/2 inch chisel turned on it's back for the scooping.
Disclosure: I've only done this once in my whole life..... 8-)
PostPosted: Mon Sep 01, 2008 7:09 pm
One Ibex finger plane and one 1/2" chisel and sand 'em pretty.
PostPosted: Mon Sep 01, 2008 7:23 pm
The chisel on the top right, a 1/2" wide short chisel with a rounded bevel, and one of those el-cheapo stanley small stamped steel planes!
Sandpaper, too. Cheap, but effective
Brad Tucker
PostPosted: Mon Sep 01, 2008 7:48 pm
Yup... Pretty much planes, chisels and sandpaper. For chisels, I tend to reach mostly for my 1" LMI chisel for carving off a lot of excess wood and tapering brace ends. I use a 1/2" Hirsch cranked neck chisel for doing any clean-up that might need to be done. For back braces I use a small plane almost exclusively for shaping. I use small sanding blocks with 80 or 100 grit paper and clean everything up.
Cheers,
Chad
PostPosted: Mon Sep 01, 2008 8:23 pm
Hi Chris!
I use mostly finger planes, the Ibex 12 and 18mm ones. I do use a paring chisel too but mostly for feathering away the ends and getting rid of the pesky excess mass at the X intersection where it is too close to get a plane in there.
I would say that 90% of my carving is done with finger planes though. You are right too Chris carving braces is the best part of guitar building for me. [:Y:]
PostPosted: Mon Sep 01, 2008 9:27 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Bandsaw, shaper, beltsander, small plane, chisle's
PostPosted: Mon Sep 01, 2008 10:49 pm
belt sander before gluing, double sided razor blades after, then sandpaper.
Burton
Brookline, MA.
PostPosted: Tue Sep 02, 2008 7:25 am
Pin router before glueup. Small plane for cleanup after gluing.
Sylvan
http://www.wellsguitars.com
PostPosted: Tue Sep 02, 2008 10:26 am
I use my block plane, scary sharp 1/2" chisel, small finger plane, and sandpaper.
PostPosted: Tue Sep 02, 2008 11:00 am
Splitting maul and an axe! :D
PostPosted: Tue Sep 02, 2008 12:38 pm
First name: David
Last Name: LaPlante
PostPosted: Tue Sep 02, 2008 1:32 pm
So THAT'S how you get 'em so clean! :D
PostPosted: Tue Sep 02, 2008 2:03 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I use a low angle block plane for the tall braces(back-#1 &#2 classicals)
And a 1/2" chisel with the corners ground smooth so it can be pushed along a fan brace and touch the guitartop without cutting into it!
The center of the chisel is still sharp to remove brace material-but no top wood dings!!
mike
Mike Collins
PostPosted: Tue Sep 02, 2008 7:44 pm
Todd, how do you like the double bevel chisel compared to the single bevel chisel? I just finished a book on carving tools and sharpening. I saw a video on Martin and the gale doing the braces just used a 1/2" chisel. Although it looked like a longer one or a longer handle. Has anyone here tried using those little brass / wood planes from Harbor Freight? I've read where they're not that bad if you sharpen the blades or put better steel blades in them.
PostPosted: Wed Sep 03, 2008 8:47 pm
I just chew the braces until they are in the perfect shape. Good toothpicks can be had, and good tone can be made.
PostPosted: Wed Sep 03, 2008 9:00 pm
Hey John Elton, I just finished watching your videos on voicing tops that arrived today. Great videos they will be a great help to me for voicing. I know what you use for shaving braces. [:Y:] [:Y:] :P
PostPosted: Thu Sep 04, 2008 5:45 am
As a matter of interest, at the Martin factory I was surprised to see it being done by hand with simply a chisel. (Including the scalloped braces). She was fast and incredibly neat! As you can see, they are not all tiny whispers of shavings either.
Rod
PostPosted: Thu Sep 04, 2008 6:30 am
As much as I like little planes, I don't use them for shaping braces. They always bump into things, besides they are really slow compared to a chisel where you can let the chips fly. So paring chisel for me, a single 3/4" Taylor (pictured) or Blue Spruce is what I like best. I rough out the shape from rectangular beams to something that looks like guitar braces quickly and then start fiddling, flexing etc until I think I'm where I want to be and sand lightly to finish up.
These braces are still oversize, of course.
PostPosted: Thu Sep 04, 2008 6:46 am
PostPosted: Thu Sep 04, 2008 10:58 am
Rod buddy fascinating pictures from the Martin factory! [:Y:]
PostPosted: Thu Sep 04, 2008 3:19 pm
Todd ,
Thanks for giving me an idea for another use of my motorized radius dish jig. I see no reason why I couldn't put my work dish in the sanding jig and place 1/4" dowels in holding position. And just turn the dish on the lazy susan to position it. Maybe add a hold down clamp to keep it from spinning while shaving the braces.
PostPosted: Thu Sep 04, 2008 3:51 pm
City: Keene
Lie Nielson block plane for the radius, then ibex finger plane, schneider plane and japanese paring chisels (usually either 3/4" or 1") for shaping. I also have various sanding sticks that I use for the finishing touches...
