It is currently Sat Jul 19, 2025 4:42 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rigid Spindle Sander
PostPosted: Wed Sep 10, 2008 8:43 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Where the heck do you put the luthier?
PostPosted: Wed Sep 10, 2008 8:53 pm
laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe [:Y:]
Brad Tucker
PostPosted: Wed Sep 10, 2008 10:21 pm
I feel better already! laughing6-hehe laughing6-hehe
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Sep 10, 2008 10:53 pm
Any of you use this in place of Belt/Disc Sander?
PostPosted: Wed Sep 10, 2008 11:48 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Yup. But, then, I do not have one (belt/disk sander)
PostPosted: Thu Sep 11, 2008 9:18 am
That's the other reason I don't have one. Where would I put it? I barely have room to move around in there. I wedge myself in and work in a 4 sq' area.
PostPosted: Thu Sep 11, 2008 9:41 am
That's just you being super efficient Waddy. Who needs 300+ sft of working space eh? laughing6-hehe
PostPosted: Thu Sep 11, 2008 2:32 pm
Rod True wrote:
cmacksam wrote:
Has anyone put a straightedge on the belt's platen to see if it's flat? How about puting a square up to the platen and the spindle to see if they're at 90deg.?
First thing I did when I got mine out of the box. The main table platen is surprisingly flat and the spindle to table platen was spot on using my engineers square. I haven't checked the belt's platen yet for flatness, I'll have to do that tonight.
Thanks very much Rod. Anybody else check theirs?
Carlton Macksam
Muskegon, Michigan
PostPosted: Thu Sep 11, 2008 2:33 pm
In the lower right hand corner of Waddy's shop!!! Is that Jimmy Hoffa hiding in there! LOL! laughing6-hehe
PostPosted: Thu Sep 11, 2008 2:55 pm
Could be! :D I can't find anything else, either! [headinwall]
PostPosted: Thu Sep 11, 2008 4:35 pm
I just bought a Harbor Freight OSS a month or so ago. Although it is only a spindle sander and has a 1/2" stroke and tops out at 4" with the sleeve up a bit. But it's also a good buy if that will work for you and it's only $80 when it goes on sale and you can get a 15% off one item coupon if you sign up for their email coupons. I just used it to scoop the end of braces. I plan on making an adjustable fence for it that will bolt to the cast table for thickness sanding smaller items. I used it to thickness my braces with just a plywood strip for a fence and a couple of clamps.
PostPosted: Thu Sep 11, 2008 6:33 pm
Any one got any ideas on how to stabilize the belt tracking .. mine is all over the place (about 3 years old now) and is pretty much useless(needless to say latelyit has only had the drums on it) .... the belt either rises up until its ready to come off, or drops down and jams/stops the motor completely.
PostPosted: Sat Sep 13, 2008 6:09 pm
Tony, check the belt length. If your idler pully doesn't extend far enough in the "run" position to tighten the belt (belt is a hair long) the tracking will be flaky. I elongated the slot that the track adjust knob feeds through with a rattail file. An 1/8" was all it took to add the travel some very slightly oversize belts needed.
I'd buy this machine again.
Dan
http://www.acme-archtops.com
PostPosted: Sat Sep 13, 2008 9:39 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Anybody notice the chainsaw in the upper left of Waddy's shop? Good for rough cuts.
PostPosted: Mon Sep 15, 2008 11:15 pm
The Ridgid is a decent tool, especially the spindle part of it. I had the same problems as Tony with the belt tracking however. After I got a 6" x 48" belt/disc combo, I sold the Ridgid and bought a dedicated spindle sander with a taller spindle and cast iron table. It was about $100 more than the Ridgid combo machine though.
PostPosted: Tue Sep 16, 2008 12:36 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I was looking at the belt the other day and noticed it was uni-directional. Apparently you cannot turn the belt over... why is that so? (it has directional arrows on the inside).
PostPosted: Tue Sep 16, 2008 5:44 am
Mike, since the belt that came with your machine may not last (this is just a guess, based on rumor) forever, you are free to buy a unidirectional belt, in a couple of years. Just look for the flush splice brfore you buy. The tipoff ones I'm used to seeing are clear-ish and shiny, kind of an eternal packing tape sort of thing.
New spindle sleeves are more of a problem, since after selling the machine, the local HD stopped carrying individual sleeves, reasoning that since I was likely to use up all the diameters in all the possible grits at exactly the same time, I would be pleased with the big grab-bag. The Sears carried what I needed, for the machine they sell. I bought a ton, so as not to be caught again.
Dan
PostPosted: Wed Sep 17, 2008 8:49 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
It turns out that HD nows stocks the sleeves.
PostPosted: Thu Sep 18, 2008 7:35 pm
I have thought about getting this sander also. My problem is space. My whole house would fit in Hesh’s basement. My garage workspace is essentially the top of my go bar deck that is sitting on the floor and a few inches either side of my drill press. All I really need is more time, money, skills, and space. gaah The sander does look pretty good though.
Philip
aka konacat
