It is currently Mon Jul 28, 2025 3:24 pm
PostPosted: Sat Nov 01, 2008 2:50 pm
First name: Kyle
Last Name: Burner
City: Lincoln
State: Nebraska
I realized this afternoon that I made a big mistake when I cute up my brace stock and braced my back. This if the first time I have done the bracing from rough stock, and so something was bound to happen. I just wish I would have caught it before I glued everything down. I oriented the braces wrong on the back, so now I have run-out on the ends of the braces. Does this warrant removing the braces and starting over? The pictures below will hopefully give you a better idea of what I am talking about. If I need to take off the braces any tips on the most efficient way to do so? Thanks for any input. [headinwall] gaah
--Kyle Burner--
PostPosted: Sat Nov 01, 2008 3:04 pm
Yes, I'd remove them and put new braces on.
Use a small block plane to get most of the material off, then go to a scraper to get the rest.
Well, for back braces, I'd leave them as they are. The only way your mistake might do tricks on you is if your guitar receives a hit from the back. Otherwise they will hold.
If you really want to take them off, the best way is to gradually chisel them out.
Alain Moisan
(Now building just for fun!)
PostPosted: Sat Nov 01, 2008 3:12 pm
Hey Rod, I heard somewhere that 'great minds think alike'.
Does that mean we're both dumb? ;)
Alain Moisan
PostPosted: Sat Nov 01, 2008 3:14 pm
No Alain, I'm pretty sure you're much smarter than I am.
PostPosted: Sat Nov 01, 2008 3:18 pm
Awwe! You're too kind...
:D
Alain Moisan
PostPosted: Sat Nov 01, 2008 3:21 pm
I'd remove them....... :D
PostPosted: Sat Nov 01, 2008 3:54 pm
According to Somogyi, wide grain spruce is actually stiffer when flatsawn, while medium and narrow grain are stiffer quartersawn. Interesting! I can see if I can find the article tomorrow, and see what he defines as wide vs med vs narrow.
PostPosted: Sat Nov 01, 2008 4:43 pm
I would remove them too , a heated spatula will soften the glue ( assuming you used some type of wood glue )and slip right in between the braces and your plate . Jody
PostPosted: Sat Nov 01, 2008 4:54 pm
Not long ago, I believed that orientating the grain like that would make the brace more split prone. Like most people, I thought wood splits more easily parallel to the grain (tangentially). Turns out, that's not necessarily true. They might be less split prone when flat sawn like that.
After milling up some samples from the same board I found that flat sawn (like in the photo) splits less easily. And looking closely at the pieces I broke, there were a lot of little fibers (medulary rays?) that span across the grain in that orientation that keep it from splitting. Give it a try.
I looked through Hoadley (Understanding Wood) and did a bit of searching on line but have not come up with much to quantify that. My guess is that it differs from one species to the next but I'm pretty sure this holds true for spruces and cedars and anything with lots of medulary rays.
As for stiffness, mostly what Lars said. Somogyi found that in less dense and medium dense (subjectively defined) spruce, flat sawn was stiffer than quartered. In dense spruce, stiffness was similar no matter what grain orientation.
This all begs the question, why did it become standard to use quarter sawn bracing?
http://www.chassonguitars.com
PostPosted: Sat Nov 01, 2008 5:05 pm
The generally accepted notion that it is more stable than flat sawn I think. I always thought that it was the main reason quartersawn is used throughout a guitar more than stiffness.
Alain Moisan
PostPosted: Sat Nov 01, 2008 5:11 pm
Bouchet used flat-sawn stock for one of the top UTBs. I've seen at least two older Martins (0 & 00 18 style) with flat sawn stock for the back braces, one even had a flat sawn neck. IMHO it doesn't matter for ladder braces.
If in doubt why not wait a few days and see if the back keeps its radius OK, as it should?
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sat Nov 01, 2008 5:18 pm
I have done quite a bit of restoration work on instruments dating back to the 18th and 19th century even a couple from the 17th century, there seems to have been no great urge to use QS braces on their instruments then and guess what, they have survived centuries just fine, indeed traditionally soundboard braces on lutes (including mine) were made flat sawn, tall and thin. You could argue that in fact they are QS but glued on the flat sawn edge, and I have seen 17th century ones that as good today as when first glued on.
Anyway, back braces are generally structural rather than tonal, so if they are holding the dome OK, I think I'd just leave them, check on them in a hundred or so years I bet they'll still be fine.
Up to you though.
PostPosted: Sat Nov 01, 2008 5:26 pm
For plates, yes. But for braces, dimensional stability doesn't really matter.
PostPosted: Sat Nov 01, 2008 5:51 pm
I've always thought that one reason for using QS braces is that they would glue better. Glue penetrates and bonds better to the softer earlywood part of the grain then to latewood. On a QS brace the latewood makes narrow (usually) lines that run along the gluing surface, while on flat sawn surfaces the latewood can go all the way across the brace and extend for some distance along the length. This would make a weak patch in the glue surface. I have to say I have not put this to a rigorous test yet; if I've noticed differences in the course of repair work it may be that I was primed to see them. I wonder if the Forest Products Lab has done anything like that?
PostPosted: Sat Nov 01, 2008 6:01 pm
Alan, I've seen plenty of two and three hundred year old flat sawn braces and bridges that were still glued just fine, I've noticed no difference between flat or QS as to whether they have come unglued. That said, they were all glued with animal glues, I don't know if the same would be true for PVA or Aliphatics.
PostPosted: Sat Nov 01, 2008 6:18 pm
Quarter sawn is better for strength it's like a beam,hard to bend .Rift sawn is like plywood,it bends easier.That is why neck wood is almost always quartersawn.I don't want my braces bending as they are for support.So i always use quartersawn for braceing ;)
PostPosted: Sat Nov 01, 2008 6:29 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Kyle, I did the same thing you did on my first. The two bottom braces on the back were flatsawn. When I was looking at the end of the chunk of wood I saw the marks made by the saw and thought it was the grain. I didn't realize it until I had to cut the top two back braces. I glued them in anyway not knowing if I'd have enough brace wood to finish.
Thats been about five months ago when I glued them in and glued the back to the rims and they still are holding their radius just fine. I also used hide glue but I don't think using Titebond would matter.
PostPosted: Sat Nov 01, 2008 6:40 pm
First name: Kyle
Last Name: Burner
City: Lincoln
State: Nebraska
This is why this forum is so valuable. Thank you all for your responses I braced the back almost a week ago and it is still holding it's shape so as far. Being that it is still holding the radius I am starting to think I may go with the braces as is.
--Kyle Burner--
PostPosted: Sat Nov 01, 2008 7:16 pm
I'd leave em be. Especially on the back I don't think it'll matter that much. On the top I'd suggest QS orientation, but here again you'll probably b fine regardless.
PostPosted: Sat Nov 01, 2008 7:40 pm
I have seen many older martins that are the same way. this is your guitar and if you are the kind of guy that this will eat you up , them pop them off and replace them. It is easy to do at this point and you can do it that it won't be seen
john hall
PostPosted: Sat Nov 01, 2008 10:16 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
I wouldn't mess with taking them off and replacing. But as someone said, if it bothers you change them. I doubt will have any problems on them as back ladder bracing. Top, would replace them.
PostPosted: Sat Nov 01, 2008 11:47 pm
I think you're fine....
PostPosted: Sun Nov 02, 2008 7:15 am
Well there you go Kyle - I was rong...... :D But this is why I wanted you to post this on the forum because I thought it was a gray area that could go either way. Build on dude :D
PostPosted: Sun Nov 02, 2008 7:13 pm
First name: Kyle
Last Name: Burner
City: Lincoln
State: Nebraska
No hesh I don't think you were wrong, after reading all this and thinking I think it is a very gray area. The back will probably be weaker given the orientation grain, but given that the back is holding form I think that the strength of the braces will be sufficient for their purpose. More than one thing went wrong yesterday with the build I guess we all have our bad days. Just gotta keep moving forward and learning from all my mistakes.
--Kyle Burner--
Users browsing this forum: ChuckB and 8 guests
