It is currently Sun Sep 14, 2025 1:17 pm
 Post subject: Laser for pearl
PostPosted: Tue Nov 04, 2008 11:33 pm
I have a 75 watt Epilog. It's very good for pearl veneers and abalam up to .030.
I use slow speed & low power.
myspace.com/mikebrittain
Mike Brittain
gmbrittain@gmail.com
 Post subject: Re: Laser for pearl
PostPosted: Wed Nov 05, 2008 4:45 pm
First name: Nelson
Last Name: Palen
That's interesting, Mike.
What kind of cut surface does it leave?
Nelson
PostPosted: Thu Nov 06, 2008 2:35 pm
The edges are very clean & sharp. Any burning will clean right off.
I will say that the learning curve is tough, similar to cnc routers etc.
Mike Brittain
PostPosted: Thu Nov 06, 2008 8:02 pm
First name: Erik
Last Name: Hauri
State: Maryland
Is that laser a CO2, YAG or FIBER?
The member formerly known as erikbojerik....
PostPosted: Fri Nov 07, 2008 10:44 am
This may be true with a laminate like ablam as the laminating media may keep the shell veneers from disintegrating, but laser will not work with natural shell as the heat powers the shell near a 64th of an inch either side of the beam and makes for very raged edge. I have been through the testing of natural shell being laser cut several times at several differnt settings and speeds. water Jet works great. I am supprised that it work on ablam. would love to see close-up photos.
PostPosted: Fri Nov 07, 2008 11:40 am
You may want to call Bob Rigaud at http://www.rgmusic.com/ To find out about the details of using a laser on Pearl and abalone. He has been using it for quite some time and his inlay work is really good. Hes a super nice guy too and loves to talk to other luthiers.
cron
