It is currently Mon Jul 28, 2025 10:49 pm
 Post subject: truss rod mounting
PostPosted: Fri Nov 07, 2008 12:13 pm
First name: John "jd"
City: Santa Barbara
Working on guitars #4 (walnut/paduk solid body electric) and #5 (Bocote 000).
My previous builds used the Martin-style truss rod which I securely epoxied in place and covered with an epoxied in shim. For the new builds, I am switching to a Allied truss rods that I learned about on this furum. I was planning to epoxy the rod in and cover with a epoxied in shim. I was suprised to see a comment in the LMI catalog that said that most Luthiers do not glue the rod in place.
What is the normal method for mounting this style of rod ?
Glue it in ? (if so, how to protect threads from the glue ?)
Leave in floating and cover with a glued-in shim ?
Leave the rod and the shim floating and just glue the fingerboard ?
thanks,
-jd
 Post subject: Re: truss rod mounting
PostPosted: Fri Nov 07, 2008 12:50 pm
thanks,
-jd
"I securely epoxied in place" (Please tell me it ain't true Joe, say it ain't true!!) "and covered with an epoxied in shim"
Question what good does it do to epoxy in a truss rod? I understand maybe using a caulking to avoid buzzing but the freedom of the rod to warp its shape is the entire point behind and adjustable rod. Gluing the rod in with epoxy just inhibited the rods movement. Now if the rod is adjusted enough to break the epoxy bond you have broken epoxy flakes that can buzz against the rod. Same on the top shim! The only real point to a top shim is to bring the rod level and the neck/fretboard level to equal. No real point to epoxy in or even glue in for that mater if the rod and shim is properly fitted and loaded.
PostPosted: Fri Nov 07, 2008 1:13 pm
City: Santa Barbara
My purpose for epoxying the C-shaped section of the martin rod in place was to couple it to the neck wood. I wanted to evenly distribute the forces generated by the bending rod. If I leave the rod floating, it seems that it would result in point loads in the middle and at both ends.
-jd
PostPosted: Fri Nov 07, 2008 2:15 pm
Allied style or LMI, I place a dab of caulking under the ends, and in the middle to prevent rattle. No shim. That's all! No problems yet.
Brad Tucker
PostPosted: Fri Nov 07, 2008 2:35 pm
The Martin style truss rod is housed in a U-shaped aluminum extrusion and most installation instructions say to glue the sides of the extrusion to the neck with epoxy. The interior rod is free-floating and protected from the glue by the U-shaped extrusion and a paper covering on the open side of the U.
The Allied style rod should definitely NOT be glued into place.
PostPosted: Fri Nov 07, 2008 4:07 pm
I think the new allied rod fits in a 1/4" wide 3/8" deep channel which is alot smaller than the channel for the gotoh rod.That's a big difference! :)
PostPosted: Fri Nov 07, 2008 6:27 pm
Do a search on the forum for Mark Blanchard. He designed the Allied rod and has good tips for installation.
Terry
PostPosted: Fri Nov 07, 2008 11:53 pm
The instructions for the Allied rods actually instruct one to to roughen up top of the rod and epoxy filler strip to same.
PostPosted: Sat Nov 08, 2008 10:05 am
For the Allied rod, make the slot .400 inches deep. Put the rod in dry and epoxy a filler strip to the back of the rod and the sides of the slot. Clamp it down lightly to remove space but not so tightly that is makes the rod hard to turn. After the glue is dry, plane the filler off so that it is flush with the neck shaft.
Mark
PostPosted: Sat Nov 08, 2008 10:51 am
Mark
Why is a filler strip required with this rod?It looks like the adjuster will clear the top plate without one.Why take out more wood than you have to from the neck?
PostPosted: Sat Nov 08, 2008 11:53 am
I'm with Mark G on this one. Are we talking about the dual action trussrod that LMI sells (and Allied) with the flat barstock on top, which bears on the fingerboard? I cut my channel just deep enough to allow the flat part of the rod to sit flush with the top plane of the neck. Although, I do install them where the adjustment sits flush with the block when viewed from inside the guitar. The flat part of the rod bears directly on the fingerboard. I've yet to have any problems; of course I don't have any 20 year old guitars out there either.
Now, if I were to use a longer rod, and extend it through the upper transverse, I would consider going deeper in order to allow the access hole in the UTB to be drilled in its center if need be.
just my de-valued .02 cents.
Brad Tucker
PostPosted: Sat Nov 08, 2008 1:03 pm
Location: Between Bordeaux and the Atlantic. S.W.France
I assume that was advice from the guy who designed it. If he says do it that way, I'll do it that way!
PostPosted: Sat Nov 08, 2008 1:34 pm
How close to the nut is the end of the rod when installed your way? I like to keep them 1/2" away. Are yours any closer than that to get it away from the transverse brace for adjustment room?
PostPosted: Sat Nov 08, 2008 1:48 pm
City: Santa Barbara
Mark
Thank you very much.
I just measured the slots I had already routed at 0.42" so I am pretty close.
-jd
PostPosted: Sat Nov 08, 2008 2:06 pm
It probably ends up somewhere in that area, Mark. I like to have it close to the end of the fingerboard on that end, but not too close. The adjustment (allen head) usually comes out about flush with the neck block if viewed from the inside of the box, give or take. I have tried flush, slightly recessed, and slightly protruding (1/16" or so). They make for a little more difficulty in adjusting because you have to reach into the soundhole, but I don't like the support block under the fingerboard extension, so this is how I do it for people who don't like the adjustment at the peghead. I use the LMI dual action trussrod currently, but I like the Allied and may change over sometime.
Brad Tucker
PostPosted: Sat Nov 08, 2008 2:19 pm
Brad T wrote:
It probably ends up somewhere in that area, Mark. I like to have it close to the end of the fingerboard on that end, but not too close. The adjustment (allen head) usually comes out about flush with the neck block if viewed from the inside of the box, give or take. I have tried flush, slightly recessed, and slightly protruding (1/16" or so). They make for a little more difficulty in adjusting because you have to reach into the soundhole, but I don't like the support block under the fingerboard extension, so this is how I do it for people who don't like the adjustment at the peghead, which I personally prefer, because it makes adjustment much easier. I use the LMI dual action trussrod. I don't recall LMI saying anything about using shims, gluing wood to the sides of the slot, etc. I just cut my slot deep and wide enough to accept the rod.
Thanks Brad,Sounds good.I have never glued a rod in yet nor will i ever.That would be the fastest way to cause a rod to fail.It's bad enough that it has to fight string tension.let alone fightint the neck as well eek If you really think about it,metal bends on a truer arch than wood does ,so why would you want the neck to guide the trussrod?The reason i got this rod was so i didn't have to shim or glue. ;) Mark
PostPosted: Sat Nov 08, 2008 2:36 pm
If you don't shim the LMI or Allied rod better at least use caulk in the channel or be prepared for a phone call from some customer about a rattle.
Terry
PostPosted: Sat Nov 08, 2008 2:47 pm
Terry
There is no reason for a truss rod to rattle unless it's improperly installed or tensioned unless badly made or broken.I wax mine in and have never had a problem. ;)
PostPosted: Sat Nov 08, 2008 4:15 pm
What does "waxing in" mean Mark? That's a new one for me.
Terry
PostPosted: Sat Nov 08, 2008 4:43 pm
I use wax instead of cauck.It stays pliable and lubricates the threads on the rod while stopping rust at the same time.It also lets the rod slide better when flexing against the bottom of the fretboard.I encase the whole rod in it. Any play or vibration that can cause rattle is absorbed by the wax.It also makes the channel more solid as though there isn't a channel or rod at all,but allows the rod to do its job without binding.
PostPosted: Sat Nov 08, 2008 6:38 pm
I use caulking....under the ends and in the middle.
Brad Tucker
PostPosted: Sat Nov 08, 2008 7:08 pm
I'm going with the allied rods as they look to be well made.I like the stainless steel also.I'll still wax them in as that keeps the glue off as well. :)
PostPosted: Sat Nov 08, 2008 8:45 pm
I like that wax idea a lot. Makes sense. I've always used caulk. What kind of wax do you use Mark?
Terry
PostPosted: Sat Nov 08, 2008 10:26 pm
I use a wax that doesn't get hard so it can keep working.Actually the best i have found is what they use for toilet wax rings.It's an anti bacterial wax that stays soft which enables the rod to move unrestricted when adjusted.You get quite a bit of it on those rings,and it's real cheap.I use it for alot of other things as well.I use it to lube neck screws as well.They go in alot easier without the chance of breaking with this wax on them.I use it between the neck and body on strats to get a more positive seal there as well.It sort of fills all the voids for better neck to body contact. ;)
PostPosted: Sun Nov 09, 2008 12:21 pm
Thanks Mark.
Terry
Users browsing this forum: Dmaxwell, meddlingfool and 17 guests
