It is currently Mon Sep 15, 2025 1:15 am
PostPosted: Mon Jul 07, 2008 6:21 pm
Here is are the kinks to Tutorials in the archive
Bob
Arm Rest
Laskin Arm Rest - Tony Karol
Backs
Back Joint Reinforcements - Hesh Breakstone
Installing Back Strips - Hesh Breakstone
Bindings and Purflings
Installing Paua Purflings - Bob Connor
Binding a Fingerboard - Brad Goodman
Installing Binding/Purfings - Hesh Breakstone
Installing Binding/Purfings Part 2 - Hesh Breakstone
Bracing
X-Brace Tutorial - Lance Kragenbrink
Bridges
Fitting a Bridge Patch - Jim Watts
Classical Bridge Tutorial - Brad Goodman
Pinless Bridge - Dave White
Bridge Removal - Hesh Breakstone
Fitting Bridges - Hesh Breakstone
Turning Bridge Pins - Louis Freilicher
Turning Bridge Pins - Kevin Gallagher
Making a Bridge - Hesh Breakstone
CNC
Rhino CAD - Neck Modeling Tutorial - Parser
Cutaways
Seamless Florentine Joint - Rod True
Double Top
LPMc Double Top - Larry Mcutcheon
End Grafts
Curved End Graft - Allen McFarlen
End Pins
Turning End Pins - Louis Freilicher
Fingerboards and Frets
Fret Levelling - Kelby Van Patten
Fret Press Arbor and Fretting - Hesh Breakstone
French polishing
French Polishing - Orville and Robert Milburn
Finishing
Poly vs Nitro - Rick Turner, Mario Proulx, Kevin Gallagher et al
Gap Filling
Filling Gaps - Hesh Breakstone
GoBar Deck
Mobile Go Bar Deck - Ron Wisdom
Headstocks
Headstock Binding - Anthony Zlahtic
Diamond Volute Carving - Matt Gage
Slotted Headstock - Brad Goodman
Hot Hide Glue
Hot Hide Glue Tutorial - Hesh Breakstone
Lap Joints
Cutting Lap Joints - Bob Connor
Linings
Reverse-kerf lining tutorial - Dave Stewart
Mitre Joints
Bench Sander Miters - Alain Desforges
First Time Miters - Dave Anderson
Molds
How to Make a Guitar Mold - Claire Arendse
Outside Molds - One Method - Todd Stock
Molds for Blanket Bending - One Method - Todd Stock
Necks
Fitting a Neck - Hesh Breakstone
Elevated Fingerboard and Faux V Joint - Gary Lee
V-Joint Tutorial - Joshua French
Correcting Back Bow - Hesh Breakstone
Shimming Neck and Tail Blocks - Hesh Breakstone
Cutaway Neck Joint - Mark Blanchard
Setting Neck Angle - Robert Dobbs
Installing Side Markers - Hesh Breakstone
Installing Side Markers - Revisited - Hesh Breakstone
Quick and Dirty Peg Head Bevel - Louis Freilicher
Elevated Fingerboard & V-Graft - Gary Lee
Nuts
Making a 12 String Nut - Paul Woolson
Pickups
Mounting Pickups - Ken Hodges
Resawing
Splitting and Resawing a Bolt of Spruce - Rich Fry
Rosettes
Box Miters Made Easy - Michael Payne
Making a Rosette - Ron Wisdom
Rosette Jig - Sylvan Wells
Making Rosettes Part 1 - Mike Collins
Making Rosettes Part 2 - Mike Collins
Making Rosettes Part 3 - Mike Collins
Making a Classical Rosette Part 1 - John Elshaw
Making a Classical Rosette Part 2 - John Elshaw
Making a Classical Rosette Part 3 - John Elshaw
Soundhole Binding - Paul Woolson
Circle/Purfling Cutter - Waddy Thomson III
Setup
12 String Intonation - Andy Zimmerman
Sides
Side Tapes Using Hide Glue - Todd Stock
Tapering the Ribs on a Table Saw - Todd Stock
Laminating Double Sides - Steve Saville
Bending Sides - Hesh Breakstone
Bending Small Pieces - Mario Proulx
Bias Tape Side Supports - Hesh Breakstone
Making a Side Profile Template - Colin Symonds
Making a Side Profile Template - Jon Kendall
Truing Upper Bout - Hesh Breakstone
Sound Ports
Sound Ports - Paul Woolson
Sound Ports 2 - Paul Woolson
Templates
Full Body Template - Todd Stock
Tools
Micro Plane Building - Chris Verhoeven
Tops
X Brace Tutorial - Lance Kragenbrink
X Braces - Hesh Breakstone
Spanish Tourniquet - Jointing Tops - Martin Turner
Tape Method - Jointing Tops - Hesh Breakstone
Wood Billets
Splitting Billets for Runout Free Braces - LMI
Wood
Harvesting and Processing Spruce - Part 1 - Shane Neifer
Harvesting and Processing Spruce - Part 2 - Shane Neifer
Harvesting and Processing Spruce - Part 3 - Shane Neifer
Armadillos
Armadillos - How to get rid of - Ron Wisdom et al
Bob Connor
Geelong, Australia
These users thanked the author bob_connor for the post: Michiyuki Kubo (Fri May 30, 2014 7:51 am)
PostPosted: Tue Nov 11, 2008 11:23 am
Bob,
I'm having trouble bringing up some of the tutorials, the ones by Hesh. Is there a trick that I don't know about, or are they no longer available for some reason?
Walter
Walter Lay
"It's taken me so long, but now that I know
I can see. All that I do or say, is all I ever will be"
- Billy Joe Shaver
PostPosted: Tue Nov 11, 2008 11:42 am
FOr those of you who don't know, Bob has expended a tremendous effort to pu these together. When the forum moved into a new software package, a lot (most, all, I don't know how many..) of the links were broken.
THANK YOU BOB! This is the "best of" the OLF in my opinion. Your passion, dedication, and efforts are world wide reknown. Thanks again bliss
PostPosted: Tue Nov 11, 2008 11:53 am
I just PMed Bob Connor and asked him if he could look into it.
PostPosted: Tue Nov 11, 2008 12:12 pm
Some of these reside on the old OLF server, and as Lance said in another thread, that site has to be rebooted.
PostPosted: Tue Nov 11, 2008 6:08 pm
Is rebooting that server something that is doable or are all of these toots forever lost? :cry:
PostPosted: Wed Nov 12, 2008 11:39 am
I was speculating, based on the jigs and tools thingy being unavailable too. I don't know if anything has been lost, one way or another. Lance just said the old site needs rebooting for that to work. I put 2 & 2 together and got 5. :D
PostPosted: Wed Nov 12, 2008 11:53 am
Once again, thanks to all who contributed to the toots and who searched them out after the switch to the new software. [:Y:]
PostPosted: Wed Nov 12, 2008 3:29 pm
I agree Pat. The archived tutorials are a great resource. I have made use of the one on hide glue, but it's time for me to make another batch and I wanted to refresh my memory, but it didn't come up (neither my memory or the totorial). Then I tried a few others and it kind of looks like Hesh has been censored.
Walter Lay
- Billy Joe Shaver
PostPosted: Wed Nov 12, 2008 4:07 pm
Walnut my friend no worries please I am sure that there is no foul play here. I don't understand why my toots and seemingly only my toots are not working all of a sudden but I am sure that there is no hidden agenda.
Trust me - no one is sadder about this than I am........
I am very glad that the HHG toot helped you and if you have any questions, ever, just PM or email me and I am always happy to help.
PostPosted: Wed Nov 12, 2008 4:46 pm
None of the links at the top of the current OLF page work right now. All, I believe, for the aforementioned reason.
PostPosted: Thu Nov 13, 2008 4:32 pm
Hesh's tutorials are working again. Yea! bliss
PostPosted: Thu Nov 13, 2008 4:53 pm
Hey Waddy thanks for letting us know!!! [:Y:] [clap] [clap] [clap] [clap] [clap] And thanks to Lance and Brock for rebooting the old server! [:Y:] [clap] [clap] [clap] [clap] [clap]
And I suspect, or have a gut feeling that there were some others who helped here too so thanks to you folks too!!!!!
PostPosted: Thu Nov 13, 2008 10:46 pm
Indeed!
We need to pull a few of the toots off the old server, they some how
didnt make it into the archive DB and are floating over there in the main
forum section. So we are debating on having our developers archive the entire
old OLF and bring it over, or just grab the important stuff, and copy it over here.
Always something to do ;)
PostPosted: Fri Dec 11, 2009 4:33 pm
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
wow ive got loads of info to take in
i havent seen any of this before thanks to those involved
PostPosted: Fri Dec 11, 2009 7:17 pm
Last Name: Abercrombie
Yup-
Great resource.
It seems that the tutorials on http://luthiersforum.3element.com aren't loading, though.
Hey, Hesh! I'm sure it's nothing personal!
PostPosted: Fri Dec 18, 2009 4:24 pm
This is one of those situations where there is no easy answer.
We went through all of this when we converted off of the WebWiz software and went to phpbb software. Some of the threads didn't convert clean. We do have them still on the old server, but we need to move all of these "other" threads over by hand and that is a daunting challenge.
We need to just bite the bullet and do it.
