It is currently Tue Jul 29, 2025 11:29 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: Chisels
PostPosted: Mon Nov 24, 2008 9:38 pm
PostPosted: Mon Nov 24, 2008 11:13 pm
There's alot of good old carbon steel for sale on Ebay. I've noticed that prices have gone up, but you still can get great chisels for less than half the price of new ones that aren't as good.
PostPosted: Tue Nov 25, 2008 12:42 pm
From my woodcarving book Chris Pye says that the bevel angle for the chisels is mostly determed by how high or low you want to hold the chisel for the most part. I keep wanting to spring for the double bevel chisel that Todd mentioned. I had it in my hand at Woodcraft but upon inspection I noticed the Tang was bent as the handle was off some and they haven't got a new one since.
PostPosted: Tue Nov 25, 2008 1:47 pm
City: Keene
Mike O'Melia wrote:
You are gonna laugh when you read this, but it never occured to me to turn the chisel upside down oops_sign
OK, maybe I will splurge on a finger plane.
Absolutely!.... Bevel up for shaping the sides of the braces, bevel down for shaping the ends of the braces...
Justin
PostPosted: Tue Nov 25, 2008 1:56 pm
That's odd, I use it pretty much with the bevel down everywhere. Seems like I only use the flat towards the work when I flush cutting something or in squaring up mortice walls or something. How do you pull out of the side of the brace when it digs in?
PostPosted: Tue Nov 25, 2008 3:22 pm
Country: Romania
I carve the braces with the top sitting in my lap :oops: , I rotate it and flip it all over so switching chisel sides helps finding the right attack angle :)
Build log
PostPosted: Tue Nov 25, 2008 3:29 pm
Holding it in your lap and carving it !!! I have to say you have more balls then me. But then again, maybe not. :o
PostPosted: Tue Nov 25, 2008 5:54 pm
Country: Romania
So far I only managed to stab my knee, luckily it went on a tangent and just shaved some skin. One of those sturdy leather aprons should be good for this type of thing. My problem is that I build in a couple corners of my ....office, I dont have an actual bench, etc etc [headinwall] I have to use the knee-bench often.
Build log
PostPosted: Tue Nov 25, 2008 6:15 pm
Is that a plexi template ? I would imagine some 1/4" dowels in a mdf radius work dish would be OK. too. What do you think Todd?
PostPosted: Tue Nov 25, 2008 9:10 pm
City: Keene
I just go slow and "feel" the wood. if it starts to dig I stop and come at it from the other direction ( it helps if you split your braces also)... I do use the bevel down for scalloping also...
