It is currently Wed Jul 30, 2025 6:32 pm
PostPosted: Mon Dec 08, 2008 12:42 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
Ok - I'm to the point where I need to build a box so I can ship my guitar body and neck to Joe for finishing. He told me that most of you folks have special boxes you've made to send him the guitar.
I'd like to see what you use - and some dimensions would help.
Where did you get the box you started with?
P A U L B U R N E R
Burner Guitars
PostPosted: Mon Dec 08, 2008 1:08 pm
City: Keene
I'm expecting one back from Joe any minute know.. (where is that confounded mailman?) I'll post pics of the box when I have it back...
Justin
PostPosted: Tue Dec 09, 2008 11:03 am
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
I am about to ship one to Joe.
After talking with him I'm using a 24x24x12 heavy duty cardboard box. It will be "lined" (sides, bottom and top) on the inside with 3/16" cabinet back plywood for "puncture" resistance. I bought some scrap furniture foam in 4" thickness from a local upholstery shop. There will be a layer of foam on the bottom, the middle layer will have cut outs for the body, neck and a slot for the bridge so Joe can verify the size and location to be masked off and finally the top layer of foam.
Don't have a photo yet, but this description ought to give you a starting point.
I figure the box ought to last a couple of shipments both ways and then I'll just transfer the innards to a new one. Total cost so far is $15 ( I got scrap plywood from a friend who owns a cabinet shop).
Hank Mauel
PostPosted: Mon Dec 15, 2008 6:42 pm
First name: Hank
Last Name: Mauel
Here are pics of the box I put together. Total weight was 25 lbs and it cost about $35 to ship FedEx ground to Indiana from California.
Top to bottom:
Top layer of 3/16 plywood, ready to tape box shut
Foam wrapped neck and surrounding foam
Body and neck in center section of foam
Box with side and bottom 3/16" plywood before bottom layer of 4" foam
Box with bottom
Hank Mauel
PostPosted: Mon Dec 15, 2008 6:52 pm
Last Name: Burner
City: Lincoln
State: Nebraska
This is great - thanks
What are the dimensions of the box?
P A U L B U R N E R
Burner Guitars
PostPosted: Mon Dec 15, 2008 7:04 pm
In answer to Paul's question:
Hank Mauel wrote:
...I'm using a 24x24x12 heavy duty cardboard box.
Hank, thank you for posting that info and the pictures.
PostPosted: Mon Dec 15, 2008 7:17 pm
I've shipped a bunch of guitars in this type of case. I've got two now. They are pretty much indestructible and give peace of mind. Total weight is around 30 lbs with a guitar inside. It's about $50 from MN to California UPS. I got mine from Atlas Cases in Denver. They were around $300 a few years ago but will last forever and can really take a a lickin'. I used cut up egg crate mattresses that the local hospital or nursing homes throw away for padding. So far everything has come through great.
http://atlascases.com/molded.html#molded
Terry
Users browsing this forum: Chris Ensor and 13 guests
