It is currently Wed Jul 30, 2025 6:23 pm
PostPosted: Fri Dec 19, 2008 8:53 am
Hey everyone
I have been using the LMI Dozuki fret saw for the last couple of years. It took a bit of work to get the drift, but with it I can now easily cut an entire Ebony fretboard in about 20 minutes, with no effort at all.
Unfortunately, it is a very fragile saw and the poor thing is just too worn out (about half the teeth are missing). The worst thing is that they don't offer it at LMI anymore.
There is no way that I am going back to the old fret saw offered in more lutherie stores. Must have a Dozuki or at least something better than the traditional saw that will do the job properly.
Does anyone know where I can find a Dozuki with a .023 kerf, or any other type of saw that they use which is better than the LMI/Stew-Mac model?
Cheers,
PostPosted: Fri Dec 19, 2008 8:59 am
Hi Pat - Did you see these at Woodcraft? I see one that has a .025 kerf: http://www.woodcraft.com/family.aspx?familyid=3901
PostPosted: Fri Dec 19, 2008 9:20 am
Country: Romania
I like the mini z saw, at both Madinter and Dick. The kerf is 0.49mm. I change the blade after each guitar just to stay sharp ( I use it for everything including kerfed linings etc.) Eat Drink
Build log
Last edited by Alexandru Marian on Fri Dec 19, 2008 9:25 am, edited 1 time in total.
PostPosted: Fri Dec 19, 2008 9:22 am
Pat, Japan Woodworker has a fret saw with a .022 kerf.
http://www.japanwoodworker.com/product. ... t_id=13085
PostPosted: Fri Dec 19, 2008 10:03 am
City: Lawrence
Zip/Postal Code: 66047
These are cheap but you can get a couple of fret boards out of one.
http://www.harborfreight.com/cpi/ctaf/d ... mber=39273
PostPosted: Fri Dec 19, 2008 12:59 pm
Hey again
I am leaning towards the ones recommended by Hesh and Lillian, but I would like to know first if anybody has ever tried either of them.
I am not too worried about a couple of thousandths off the .023 standard, but the one Hesh recommended is a double edge Ryoba, and therefore has no blade support along its length. I wonder if that could make it tend to wobble at the early stages of the cut.
All feedback is much appreciated! Thanks bliss
PostPosted: Fri Dec 19, 2008 1:05 pm
Hida tool:
http://www.hidatool.com/index.htm
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Fri Dec 19, 2008 1:30 pm
I have both styles of saws and find myself reaching for my smallest Z-saw for most of my cutting. If I need a deeper cut, I start with the smaller blade then grab the larger one. Both have a stiffener. I only use the Ryoba out in the shop for course cutting. It may get relegated to course work because I need to work on my technique. But I can say without hesitation that I love the Azebiki (panel) saws for the fine work. My most reached for saw is my Z-saw Brand Mini Panel Saw hands down.
PostPosted: Fri Dec 19, 2008 2:30 pm
I use the folding dozuki from Lee Valley. It's relatively cheap, you can buy replacement blades and it cuts a .023" slot.
PostPosted: Fri Dec 19, 2008 3:52 pm
Hey Darrel
Are talking about this item?:
http://www.leevalley.com/wood/page.aspx?c=1&p=41736&cat=1,42884
It doesn't give the kerf size but if you say it works, I'll take your word for it...(Lee Valley is just my favourite store!!!) [:Y:]
PostPosted: Sun Dec 21, 2008 1:04 pm
That's the one Pat. Works well for me.
Darrel
PostPosted: Sun Dec 21, 2008 3:52 pm
Hi Darrel
Excellent. I'll be ordering it. Many thanks.
PostPosted: Sun Dec 21, 2008 4:10 pm
I've made my own (although I use the table saw now) from the Stanley flush cut saw. It cuts on the pull stroke and is Dozuki style in the teeth. You can buy them at most of the big box stores and online (amazon usually sells them for about $14).
Here's the saw as it comes.
And here's my fabricated fret saw. Cuts a 0.023" kerf and I've made a couple other little saws for cleaning out the fret slots for a re-fret or cleaning out the glue from binding the fretboard.
I set the blade in the handle at the correct depth of cut for the fret slot so I won't cut to deep into the fretboard.
PostPosted: Sun Dec 21, 2008 8:24 pm
Online
First name: Josh
Last Name: French
City: Houston
Does anyone know of one that works well with the stewmac miter box? Thanks!
Instagram: @jfrenchluthier
Users browsing this forum: meddlingfool and 14 guests
