It is currently Sat Aug 02, 2025 5:10 pm
 Post subject: Classical FB plane?
PostPosted: Sat Jan 17, 2009 12:53 pm
I have the Bogdanovich and the Cumpiano books but I still have to draw things out for myself to feel comfortable building. I can't find where I want the FB plane in relationship to the soundboard at the bridge location, using a 5/16" bridge. From my initial drawings it looks like I want the line of the top of the FB an 1/8" above the soundboard at the bridge location. Is this correct? Clinton
 Post subject: Re: Classical FB plane?
PostPosted: Sat Jan 17, 2009 1:00 pm
Country: Romania
1/8 is just sweet (without frets)
Build log
PostPosted: Sat Jan 17, 2009 2:20 pm
Make your calculations so that the strings are 10mm-12mm off the soundboard when finished. That usually puts the bridge height in the 7mm-9mm range.
PostPosted: Sat Jan 17, 2009 4:01 pm
Yes, I read that using an 1/8 saddle my strings should be 10-12 mm off the soundboard. I use the formula .039 times the mm = inch from the book on all my calculations! :oops: I've noticed that classical builders love the metric system..I've been trying to teach myself the relationship between the two,but it's hard for us old folks...or the less educated. :oops: Is there a benefit for the reverse neck angle over the flat? Easier to play? Clinton
Users browsing this forum: No registered users and 40 guests
