It is currently Sat Aug 02, 2025 1:08 pm
PostPosted: Tue Feb 03, 2009 6:27 pm
First name: joe
Last Name: kelly
City: glasgow
Country: uk
hi every one ......great forum......for years i have been filling the pores in my guitars with what ever finish i was using at the time. although it looks very natural and clean i have had enough......im losing so much money through time wasted by constant cutting the finish back that i am going to start using a grain filler........i enjoy using dust and shellac but thought i would use z poxy to give it a try ....im still waiting for it to arrive in the post and i was wondering if the z poxy drags some of oils out of the rosewoods into maple bindings etc and would i have to seal the lighter bindings before using the z poxy???? [:Y:]
PostPosted: Tue Feb 03, 2009 6:45 pm
I have never had Z-poxy drag any color, the way alcohol dissolved shellac does.
Jordan Aceto
Ithaca, NY
PostPosted: Tue Feb 03, 2009 8:34 pm
Welcome to the OLF Joe! [:Y:] [clap] [clap] [clap]
PostPosted: Tue Feb 03, 2009 9:33 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Todd,
How do you thin z-poxy?
BTW, to the OP, I just did my first use of z-poxy. On my next use, I plan to seal before cutting the binding slots, etc. Then go back and seal those. Perhaps if I get a good 6" squeegee and learn how to thin it, that won't be a concern. But I really hate all that sanding when the binding is on. The stuff is amazingly hard when cured. Just my thoughts.
PostPosted: Wed Feb 04, 2009 8:33 am
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
Welcome Joe!!
Darrin
PostPosted: Wed Feb 04, 2009 9:13 am
Mike O'Melia wrote:
Todd,
You can thin z-poxy with alcohol.
z-poxy is a bear to sand, but it scrapes like a dream, and you dont fill your shop with horrible dust when you scrape. Normal razor blades work well, as do scraper blades.
Jordan Aceto
Ithaca, NY
PostPosted: Wed Feb 04, 2009 9:33 am
If mixed right and properly cured Zpoxy sands fine. It was designed as a finish resin for fiberglass surfaces (final coat). It was designed to be fine sanded and polished. That said I have gotten the occasional and rare batch that cured a tad rubbery but for the most part it sands fine if truly cured. It also scrapes quite well too.
Zpoxy is a very forgiving 1:1 ratio mixture. You can get the ratio off by as much as 5%-10% either way and it will still cure out. However being off that much will likely cause the cured film to be rubbery. So for the best possible sand-ability accurately measure part A and part B. then mix.
PostPosted: Wed Feb 04, 2009 1:48 pm
First name: joe
Last Name: kelly
City: glasgow
Country: uk
thanks for the welcome and replies every one......i had two guitars to fill this morning....i filled one with dust and shellac and the other with z poxy finishing resin.....both were as simple to use than each other and both look real nice but i will have to slush fill the z poxy tommorow but the shellac dust one is all ready to go......i use a shellac barrier coat then colortone waterbase sealer and lacquer.........mmmmmm finishing......a real chore that seems to get tougher as the years go by....lol
PostPosted: Wed Feb 04, 2009 1:59 pm
SLUSH FILL? pleas explain?
PostPosted: Wed Feb 04, 2009 6:29 pm
First name: joe
Last Name: kelly
City: glasgow
Country: uk
hi Michael.......a slush fill is just a term used for applying a thinned down version of the full strength grain filler....i think i pick up that term slush fill from the cumpiano book.......mmmm not sure........some finishing book....ahhhh....... the stewmac finishing book.........
PostPosted: Wed Feb 04, 2009 7:30 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Will the addition of alcohol increase the tendancy of some woods to bleed?
Thanks for all the good tips!
