It is currently Sun Aug 03, 2025 1:11 am
 Post subject: Nut glueing
PostPosted: Sun Feb 08, 2009 10:44 am
Do you glue in a bone nut and if you do what glue do you use? I know a properly fitted nut doesn't need glue, but for those that do glue,what do you use on bone?
 Post subject: Re: Nut glueing
PostPosted: Sun Feb 08, 2009 10:57 am
Frank Ford recommends a tiny drop of super glue wicked in after the nut is in place. All you want is to keep it from falling out when the strings are off.
For guitars I build, I get better intonation if I remove about .008" from the bass side of the fingerboard. This makes for a slight wedge shaped nut that is easier to make a good friction fit with. Nothing worse than too much glue on your nuts....
http://www.chassonguitars.com
PostPosted: Sun Feb 08, 2009 10:58 am
Two small drops of Titebond ...
PostPosted: Sun Feb 08, 2009 11:38 am
Two small drops of Elmer's goo.
I agree on the friction fit and try to make my nuts.... snap into place.
PostPosted: Sun Feb 08, 2009 1:46 pm
Never glued one in, if it fits, it fits. Do you glue the saddle in, no, so why the nut.
PostPosted: Sun Feb 08, 2009 2:09 pm
Colin my friend the drop of glue is added insurance for when someone, other than us, attempts a string change and depending on the methodology, or lack of same, may loosen or slide the nut to one side. I agree with you that a well fitted nut really does not need to have a drop of glue on it in a perfect world but my world is unfortunately not very perfect. ;)
PostPosted: Sun Feb 08, 2009 6:05 pm
As Tony said, I'll have to use titebond on it .There isn't a channel to wedge it in and the nut bottom is level with the bottom of the board.There's no overlay on the headstock to help hold it either.Think Gibson J-45. Same as mine except where they used mahogany, i used ash neck and body both.
PostPosted: Sun Feb 08, 2009 7:32 pm
two drops of CA. And--this is important--on the side of the nut facing the board. This avoids tearing wood out when you knock it loose to change it.
PostPosted: Sun Feb 08, 2009 11:06 pm
First name: Tracy
Last Name: Leveque
State: CO
I do the same, but with one small drop of medium viscosity CA. Glue the front of the nut to the end of the fretboard. I made the mistake of using Titebond on the bottom of the nut channel and when I removed my nut, I had a lot of cleanup to do later. The front of the nut offered a much easier cleanup.
PostPosted: Sun Feb 08, 2009 11:31 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
Ok, rookie, nerdy question, but why would you need to change it? Do they wear out? Or is it if you want to change the action?
Darrin
PostPosted: Sun Feb 08, 2009 11:35 pm
Amen.
PostPosted: Mon Feb 09, 2009 12:17 am
Darrin
Cange in string gauge could be one reason, change to a higher action could be another and then there could be a refret down the ine requiring a full set-up. Oh and the clinets that think they need to lower the action some more only to find out the don't know what they are doing [headinwall]
PostPosted: Mon Feb 09, 2009 2:39 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Gotcha. Thank you, and thanks for not laughing and pointing at the dumb question guy. I am not much of a player, and a recent builder. I haven't been around guitars my whole life, so nearly all of this is new to me. Thanks again.
Darrin
PostPosted: Mon Feb 09, 2009 3:24 pm
That is a good tip Howard! It's always easier to break loose from the end grain than the side grain on the headstock.Less chance of damage too.
