It is currently Mon Aug 04, 2025 12:15 am
PostPosted: Sat Mar 07, 2009 11:59 am
Well, one of the best parts of making stringed instruments is learning that there are very few mistakes that aren't fixable and that everyone makes mistakes. :oops: I'm currently making a multi-scale Taropatch Harp Ukulele and became increasingly aware that the 11th fret is slightly out on the bass side. It was probably within bounds of "player intonation" but it annoyed me. The problem was with a bound fretboard attached to a carved neck how could I fix this? So this is what I did. I have some ebony veneer that is about 0.6mm wide and a single flute router bit that is 1.8mm. A slot routed with this bit and filled either side with the veneer would leave a perfectly sized fret slot in the middle and be covered by the fret. So first I clamped the neck in my old Workmate, took out the 11th fret and filled the gap with a piece of the ebony veneer glued in using CA glue:
The insert was scraped and sanded flush:
I measured the position of the new slot on the fingerboard ends and clamped up a fence for the laminate trimmer in the correct position - this was a cork backed sanding block:
I then carefully routed the fret slot using my laminate trimmer with multiple passes lowering the depth fractionally each time until the fret slot was 3mm deep - this is a very small and fragile router bit and will break easily. This required a lot of concentration and a steady hand:
Here's the result:
The ebony veneer strips were glued in on each side of the new slot using CA gel, being careful not to get any of the glue in the centre of the slot and using two razor blades to hold it all in place while the glue dried:
When dry I scraped and sanded it flush:
Some hot hide glue was put in the fret slot and the new fret was hammered in using a 16" radius fret caul:
The fret ends were cut flush and the bevel filed in the ends.
Job done - now that was satisfying and hopefully may be of interest to some of you :D
PostPosted: Sat Mar 07, 2009 12:04 pm
You never cease to amaze me Dave. Good fix.
PostPosted: Sat Mar 07, 2009 12:15 pm
Real nice work there, Dave.
PostPosted: Sat Mar 07, 2009 1:15 pm
Great save, Dave.
I'm sending all my repair work to you.
PostPosted: Sat Mar 07, 2009 1:25 pm
Great escape, Houdini!!!
Thanks for posting!
PostPosted: Sun Mar 08, 2009 7:58 am
So that's why you haven't finished it yet!! ;)
Great job
Mat
PostPosted: Sun Mar 08, 2009 8:29 am
Nice save! Reminds me of the post where I inlaid the 12th fret inlay in the wrong location. Had to rout out the entire 10th fret block and replace it - also on a bound board. Grrrrrr..... But these are the best learning experiences.
Wes McMillian
Santo, TX
http://www.wesmcmillian.com
PostPosted: Sun Mar 08, 2009 8:54 am
Well done that man, bet even a close inspection it'd be tricky to see
Formerly JJH
PostPosted: Sun Mar 08, 2009 11:12 am
City: Lawrence
Zip/Postal Code: 66047
Good job Dave [:Y:]
Users browsing this forum: No registered users and 42 guests
