It is currently Sun Aug 03, 2025 9:25 pm
PostPosted: Sat Mar 07, 2009 11:41 pm
Hi Everyone.
I've searched the archives for an answer to this, but I couldn't find anything tru-oil specific.
I was doing some final fitting of the neck last night, when I accidently bumped it on the edge of my workbench on the underside just south of the nut. It's just a small dent, but I really want to repair it, especially cause it's right in 'first position' so it'll be felt all the time (unless you're some fancy player who uses all the neck :) )
I've read about using CA to fill dings but I didn't want to go ahead with that b/c I've only seen that referred to as a lacquer repair. I don't think I should try to fill it with tru-oil, though. Should I just sand the dent out and refinish the area (it is quite small and really wouldn't affect the shape of the neck in any real way), or is there a way to fill it with something, and maybe put a thin coating of tru oil over, and buff it out in a few days' time?
I'd really appreciate some direction here from someone familiar with repairing oil varnish finishes.
Thanks.
-Clint Beacock
PostPosted: Sun Mar 08, 2009 7:23 am
If it's not a gouge you should try to steam out the dent without burning the finish. CA looks invisible under varnish but you'll need a couple of coats over it.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sun Mar 08, 2009 9:47 am
I recently used a couple of layers of medium CA to fill a dent on a mahogany neck finished in tru oil over zpoxy. I can't attest to the long-term effects, but right now the repair is basically invisible. I leveled the CA with a razor blade and blended with 320 and 400 sandpaper followed by something like 5 coats of tru oil. It's not as hard or wear resistant as lacquer, but at least tru oil a very easy finish to repair.
PostPosted: Sun Mar 08, 2009 4:11 pm
Thanks, Laurent and Bob.
I'll try the steam thing first, then the CA/recoat if that doesn't work.
-Clint Beacock
Users browsing this forum: doncaparker, guitarjtb and 40 guests
