It is currently Sun Aug 03, 2025 3:50 pm
 Post subject: brad point or forstner?
PostPosted: Mon Mar 09, 2009 6:57 am
do you prefer brad point or forstner bits for drilling clean holes (in head stock for tuners )? thanks Jody
PostPosted: Mon Mar 09, 2009 7:00 am
Both will work fine .. I happen to use a forstener on the drill press for tuner holes (and neck inserts)
PostPosted: Mon Mar 09, 2009 3:20 pm
I like brad point for the smaller sizes. The "screw" portion of the bit helps pull the cuttings out of the hole. Much better than the forstner bit which has a tendency to hold the cuttings in the hole more than a brad point does.
PostPosted: Mon Mar 09, 2009 3:29 pm
Brad point bits leave a groove around the bottom of the hole, Forstner bits don't. Only matters if you are trying to drill a nice flat-bottomed hole. Of course, both still leave a dimple in the center. When drilling with a Forstner, back it out of the hole often to clear the chips.
PostPosted: Mon Mar 09, 2009 6:33 pm
Thanks for the advice Steve, Tony, and Joe! Jody
PostPosted: Mon Mar 09, 2009 7:00 pm
First name: Erik
Last Name: Hauri
State: Maryland
Both - my brad points fill in the gaps in my forstner sizes.
The member formerly known as erikbojerik....
