It is currently Tue Aug 05, 2025 1:20 pm
PostPosted: Sun Mar 15, 2009 3:35 pm
I'm just getting ready to scrape bindings and purflings I have glued on several guitars I have underway. How do you get a uniform radius on the edge of the binding so that it's consistent all the way around the body? I've usually used a scraper, but is there a better way to make the consistently rounded edge? I'd appreciate your suggestions.
Ken Grunst
Williamsburg, VA
PostPosted: Sun Mar 15, 2009 5:08 pm
Drill a hole the size of radius in wood 1/2" long, cut out 110 degrees, glue sandpaper in 'cup'.You could knock it down with a scraper first. At least in theory... :)
PostPosted: Sun Mar 15, 2009 6:37 pm
I use the rubber concave sanding blocks from Lee Valley.
PostPosted: Sun Mar 15, 2009 6:54 pm
I never get too worried about the radiusing. The edges will break nicely as you sand .
PostPosted: Mon Mar 16, 2009 4:29 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
router??
Typhoon Guitars
PostPosted: Mon Mar 16, 2009 10:08 am
First name: Nelson
Last Name: Palen
I do them by hand but it does take practice and patience to get a uniform look.
Wonder if a person could use a setup same as or similar to binding rabbet routing with a small corner rounder?
Nelson Palen
PostPosted: Mon Mar 16, 2009 7:14 pm
a 1/16" roundover bit might be a tad too much, or might be just right for your tastes....that's the smallest made....
PostPosted: Tue Mar 17, 2009 8:23 am
I just use a scraper, but to stay uniform, I'll do a "primary" (ie 45) bevel all 'round. Then ease with "secondary" bevels before sanding smooth. (I find bevels are easier to check for consistancy & keep the shape truer.)
Milton, ON
PostPosted: Thu Mar 19, 2009 7:58 pm
Thanks guys:
I'm having pretty good luck with this group of guitars using a scraper and cutting several light bevels, and then sanding to a near-round finished edge. I tried Frei's method and I think it worked really well once I got the right sized tool made. I ended up doing quite a bit of bevelling first, and then finished them with this special sanding block. I tried if first without the scraper, but it was way too slow.
Ultimately, I'd like to experiment with a router, because I really want a perfect quarter-round edge, but I guess I'm still a little gun shy. There's just no room for mistakes after this many hours of work getting a guitar body to this stage.
Thanks everyone. I really appreciate the sharing here on the Forum.
Ken Grunst
Williamsburg, VA
PostPosted: Thu Mar 19, 2009 8:17 pm
One nifty trick, after beveling and refining with a scraper like Dave Stewart outlined, is to use 1/3 or so of a sheet of 220 or 320 sandpaper "shoeshine style" around the body. It makes for nice uniformly round binding edges if done attentively.
Jordan Aceto
Ithaca, NY
PostPosted: Thu Mar 19, 2009 11:56 pm
I've tried to do it with a .0625 roundover chucked up in a jig just like what routes the binding. I tried many different ways. It just didn't work. Never would come out totally even. Especially with plastic binding it's easy to do it by hand. I get a 45 degree with a small scraper, then blend the sharp edges in. Practice and it's a snap.
Users browsing this forum: bftobin and 24 guests
