It is currently Mon Aug 04, 2025 10:56 am
 Post subject: Bone or no Bone?
PostPosted: Tue Mar 24, 2009 5:04 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I`ll be doing a neck re-set on a 70`s Martin.The nut and saddle seem extremely yellow looking.I can`t re-call seeing them quite this yellow.Is it bone or no.When the customer brings the guitar over ,I may be able to tell by listening as I tap the saddle on the work bench. Is there a fool proof method for identifying bone?
James
James W Bolan
Nashville Tennessee
 Post subject: Re: Bone or no Bone?
PostPosted: Tue Mar 24, 2009 6:01 pm
James, If you can scratch an inconspicous area it should smell like the dentist drilling on a tooth if it is bone.Plastic won't smell like that.This may not be the answer you were looking for, but that's how i would tell them apart other than a hardness test.Ivory would show a crosshatch pattern in the grain.
PostPosted: Tue Mar 24, 2009 6:16 pm
Last Name: Garrish
Heat up a needle or scalpel blade. Bone has a high melting temperature, plastic doesn't.
Bob Garrish
PostPosted: Tue Mar 24, 2009 7:20 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I believe Martin was using Corian in the 70s.
PostPosted: Wed Mar 25, 2009 10:30 am
I believe Martin was using micarta in the 1970's
PostPosted: Wed Mar 25, 2009 10:50 am
Martin still uses micarta
While Corian was invented by DuPont in the mid 70's It did not come commercially available till the early 80
PostPosted: Wed Mar 25, 2009 11:03 am
70's what? You have a serial number.
My 1971 is ivory nut and saddle.
PostPosted: Wed Mar 25, 2009 11:33 am
When he mentioned reall yellow my thoughts were the same. It may very well be ivory
PostPosted: Wed Mar 25, 2009 1:13 pm
Michael.
Isn't it sort of quaint that back then, the standard guitar from Martin was equipped with elephant ivory fittings. You hardly get bone on the top of the line anymore.
PostPosted: Wed Mar 25, 2009 1:27 pm
David Newton wrote:
Michael.
Well there are those that hold micarta is a better choice for a bridge and nut. It very well could be mistaken but I belive i read some where resently that Martin as making a move to Tusq. I could be wrong but for some reason that comes to mind. It may be only on units provided with a trasducer and preamp.
Last edited by Michael Dale Payne on Wed Mar 25, 2009 1:36 pm, edited 2 times in total.
PostPosted: Wed Mar 25, 2009 1:31 pm
Not that this issue matters much, but I was a CF Martin dealer in the 1970's; not a big dealer and I never sold or stocked any high end Martins, ( mostly D18's, D28's HD28's) but at that time, the Martins I sold had micarta nuts and saddles... I would be very much suprized to learn that Martin was still offering ivory in the 1970's..maybe bone (in the early 70's) but not ivory..
maybe retro fitted but not stock
PostPosted: Wed Mar 25, 2009 1:51 pm
Martin's 1970 catalog lists ivory as standard nut and saddle material. My new '71 D28 came with ivory. That was the catalog that announced IRW in place of BRZ.
Don't know when they moved from that, could have been the guitar after mine.
PostPosted: Wed Mar 25, 2009 2:11 pm
First name: Woodrow
Last Name: Brackett
City: Grover
I always get micarta and corian confused. They're probably not even similar.
Added/Edit: My 1974 D18S had some kind of manmade nut and saddle. It wasn't bone or Ivory. It was almost 30 years old when I got it so it could have been changed. I don't think Martin used bone until recently but I could be mistaken about that too. My 1955 D18 had (and has) Ivory.
PostPosted: Wed Mar 25, 2009 5:18 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I`m pretty sure this isn`t ivory.It has a kind of puke yellow look to it.When I get the guitar in hand ,I`ll put some heat to it,if it starts to melt,it ain`t ivory.I`ll also try the scratch and sniff test.That sounds like fun!!!
James
James W Bolan
Nashville Tennessee
Users browsing this forum: JimWomack and 31 guests
