It is currently Mon Aug 04, 2025 10:56 am
PostPosted: Mon Apr 06, 2009 11:30 am
Well those of us that have bent Zootman's wonderful MAP-O-LAM in the past know that when bending it in the face up profile the curly maple wants to twist out of plane. I have dealt with this by tightly sandwiching the MAP-O-LAM between two pieces of binding and tape securely with low tack masking tape prior to bending in a fox style bender.
Well this week I wanted to bend a full circle of MAP-O-LAM to a 5 ¾ diameter for a rosette. So I knew this would have to be done by hand on a hot pipe. Well it took some time and as expected it did twist from the curl in the maple as bending. I would correct the twist as best I could while bending but was still left with a bit once complete.
I fixed it but first taping the overlapping ends of the circle to gather to prevent spring back. Then placed a slat, heating blanket, then slat on my bench. On top of that I place the slightly warped circle. On top of that I lightly clamped a ½” thick scrap piece of MDF. I brought the blanket up to 200F the slowly increased the clamping pressure till the MAP-O-LAM laid flat and let it cook for 5 min. I allowed it to cool for 2 hours and removed it and installed in the rosette.
Now I am goint to attempt to bend it to 4 1/2" diameter full circle and replace the inner purfling on this rosette as well
PostPosted: Mon Apr 06, 2009 1:56 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
Nicely done MDP! I too found that the M-O-L twisting was a problem.
I found that using the flat area of my bending iron - I could press the map-o-lam against it and flatten it out. I actually ended up using the flat area of my iron to even do the bends - slowly.
I really like your idea for use on a rosette.
I will consider it for a build!
P A U L B U R N E R
Burner Guitars
PostPosted: Tue Apr 07, 2009 2:54 pm
Last Name: Cyr
City: Roseville
OK - I guess I'm displaying my ignorance, but what on earth is MAP-O-LAM? A Google search yielded nothing even remotely related to guitar-building or luthiery, so what is it, what is is used for, and where can one get it if one is inclined to use it?
--Steve
---Steve
PostPosted: Tue Apr 07, 2009 3:28 pm
--Steve
RCtonewood makes them. they are a pre laminated purfling made up of thin line bwb-1/16 wide curly maple-thin line bwb intended gor body edge purfling. See the outer part of the rosette in this picture
Users browsing this forum: JimWomack and 31 guests
cron
