It is currently Mon Aug 04, 2025 5:56 am
 Post subject: Finish for Work Surface
PostPosted: Sun Apr 05, 2009 5:43 pm
First name: Darryl
Last Name: Young
State: AR
I'm almost completed my mobile work table that I'll be using to build my guitar on. I'm using plywood for the work surface for now. I was thinking of using wipe on poly for a finish on the worktable surface that the parts, guitar wood, etc. will be in contact with.
Do you forsee any problems using poly on the work surface? Any reason to leave it bare? Have a better suggestion?
Thanks!
PostPosted: Sun Apr 05, 2009 6:55 pm
I use 1/4" hardboard with one side white (melamine?) Stick it down with double sided tape and when it gets all beat up, replace it for a brand new top! Cleans up easily too.
PostPosted: Sun Apr 05, 2009 6:59 pm
I top most of my surfaces with 1/4" masonite and put 2 coats of brush-on poly on it. Been doing this for about 10 yrs and it's inexpensive and holds up well.
First name: Darryl
Last Name: Young
State: AR
That's not a bad suggestion. I could use formica or something similar on the top. Would the slickness cause a problem? White would probably lighten things up where I could see better.
PostPosted: Mon Apr 06, 2009 3:09 am
PostPosted: Mon Apr 06, 2009 11:14 am
I sanded with 80 grit, followed by General Finishes Outdoor Oil.
PostPosted: Mon Apr 06, 2009 6:09 pm
First name: Darryl
Last Name: Young
State: AR
When working on your bench, do you always keep something soft under the guitar back/top? If so, what are your thoughts about using cork on the work surface....possibly glued to the top?
PostPosted: Mon Apr 06, 2009 6:11 pm
First name: Mark
Last Name: Thorpe
City: Valparaiso
State: Indiana
Carpet. I don't lay anything I'm working on, on anything but carpet ( which I vacuum often). I don't glue anything over carpet, I use whatever and just wipe up the glue drips.
PostPosted: Mon Apr 06, 2009 7:17 pm
First name: Jim
Last Name: Hansen
I use the 1/4" hardboard surfaces as well. When they start to get dinged up, dirty, etc.. just pull them off an put on new ones. I don't bother to put a finish on the (just laziness)
I also have some carpet remnants for working on guitar bodies, etc... which as someone suggested above, must be kept clean and free of chips, tools, glue drips, etc... I've put some serious gouges in a nice spruce top not paying enough attention to keeping the carpet clean. In fact my sister teases me that the tops of my benches are cleaner than the carpeted floors. :p
Jim Hansen
Users browsing this forum: ChuckB and 46 guests
