It is currently Tue Aug 05, 2025 7:27 am
PostPosted: Fri Apr 03, 2009 8:55 am
I have been buying 2" cloth abrasive rolls for my Delta 18/36 in the bulk boxes and discovered that Delta has discontinued selling the large rolls. It gets expensive when you have to buy them in the 4-packs. There has got to be a source for rolls of the 2" cloth abrasive rolls in bulk. I've noticed that 3M sells 50 Yard, 2" Utility Abrasive Rolls. Has anyone tried this product or have a recommendation for another source?
Mike Franks
www.mjfranksguitar.com
PostPosted: Fri Apr 03, 2009 9:42 am
Mike Franks
http://www.mjfranksguitar.com
Mike, I looked everywhere and here's the best place I've found...especially check the clearance box...
https://www.econabrasives.com/index.php?
Hope this helps!
Larry
PostPosted: Fri Apr 03, 2009 10:40 am
I came across these folks, but have yet to try them out. Prices seem good enough to sand cocobolo, anyone have experience with them?
http://www.supergrit.com/default.asp
Gabriel Regalbuto
Carlsbad, California
Freedom 35!
PostPosted: Fri Apr 03, 2009 10:46 am
Larry, you're awesome! I called Econ Abrasives and found that they will custom cut 2" wide x 50 yd. rolls of any grit size for $37.00 per roll. I was told that their material is the same make as used by Delta & Jet. They also supply spindle sander sleeves (for under $2.00) and can supply discs, sheets, etc.
What a savings over buying the Delta 4-packs at $30 - $40! By the way, 50 yards will yield 13 pieces for the 18/36 Delta Sander.
MIke Franks
PostPosted: Fri Apr 03, 2009 11:00 am
Last Name: Garrish
I deal with these guys for other stuff, and the prices are good for me. They'll do any sort of custom belt you want at pretty good prices!
http://customsandingbelts.com/
Bob Garrish
PostPosted: Fri Apr 03, 2009 8:39 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I get mine here.
http://www.woodworkingshop.com/cgi-bin/1B552FDE/mac/subgrp.mac/subGroupSelection?lenGrpDsc=5ROLLSABRASIVE%20ROLLS%20-%20ALL%20SIZES
PostPosted: Sat Apr 04, 2009 1:38 am
Last Name: Shaw
City: Philadelphia
I have used the 3m and i think it works fine. I have recently bought some rolls for my sander from klingspor below. Cheaper compared to the 3m. I have a jet drum sander and buying the jet precut belts is pretty expensive compared to buying it by the whole roll. I have to use a original belt as a cutting template though because the jet belts taper on one end before it attaches to the drum clip...Mike
PostPosted: Sat Apr 04, 2009 7:59 am
First name: Jim
Last Name: Kirby
http://www.onlineindustrialsupply.com/drsaro.html
Buy rolls, cut your own. These work well.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Apr 04, 2009 4:31 pm
industrial abrasives in Reading PA can help. Google it and you will find
PostPosted: Sat Apr 04, 2009 7:00 pm
First name: Ken
Last Name: Hageman
City: Statesville
Zip/Postal Code: 28625
Greetings,
Klingspor makes great material for your drum sander. You can look them up directly on the internet or go to www.woodworkingstore.com. This is their retail outlet. Four locations in North Carolina. A lot of times you can find the stuff on sale or other sanding items.
They have been selling their orbital sanding paper for $5.00 a box of 50. It is a great deal
Ken
PostPosted: Sun Apr 05, 2009 9:44 pm
Industriaabrasives.com sells a roll for $70, which has enough to make 19 sets. Works out to less than $4 to wrap up your drum sander, which is a great bargain.
PostPosted: Sat Apr 11, 2009 8:59 am
First name: Erik
Last Name: Hauri
State: Maryland
You use 2" wide paper for your drum sander? I use 3" on my Performax...any reason why 2" would be preferred?
The member formerly known as erikbojerik....
PostPosted: Sat Apr 11, 2009 9:06 am
Erik, you need to use what your machine is designed for. The Delta's are designed for 2" rolls.
David White, Toronto
Users browsing this forum: Woodie G and 39 guests
