It is currently Mon Aug 04, 2025 11:21 pm
PostPosted: Thu Apr 16, 2009 2:57 pm
First name: Chuck
Last Name: Gilbert
A client brought me this wood and said that he was told it was Brazilian Rosewood. I haven't seen enough to know, but it looks and smells like some species of rosewood. I measured and weighed the board and came up with a density of about 45 lbs./cu. ft. That seems a little light but my research found average density of BRZ to be 50 - 60 lbs./cu. ft. It has been in storage for over 10 years. The dark area is where I wet it with mineral spirits.
Thanks for any help...
Chuck
PostPosted: Thu Apr 16, 2009 3:09 pm
Not to be alarmed .. but that sure looks like air dried black walnut to me.
PostPosted: Thu Apr 16, 2009 3:11 pm
I'm no expert, but it looks more like EIR to me. I don't think of BR as quite so stripey!
PostPosted: Thu Apr 16, 2009 3:50 pm
Because lighting can play trick with color I cant be for sure the two most likely possibilites I think are Claro Wanut or Goncalo Alves but the pattern width of light wood to dark wood is way more consistant than I would expect on either really. I guess it is possible to be EIRW but I am leaning towards Claro Walnut
PostPosted: Thu Apr 16, 2009 3:59 pm
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
I am as certain as I can be from my computer that you have bolivian rosewood (morado) on your hands. I recently cut up 5 sets that look identical to that. You would know if it was walnut.
Stephen
www.ziegenfussguitars.com
PostPosted: Thu Apr 16, 2009 4:34 pm
Last Name: Hodge
Chuck,
Based upon the pic supplied in your post, it looks most like East Indian Rosewood (EIR). I doubt very seriously that it is
Brazillian (BRW) because it just doesn't display the typical visual characteristics of BRW. As was mentioned above, it's hard
to really be sure with the given photo and lighting. I use a 32" HDTV as my monitor and have about as good a resolution
as possible for a computer screen. I still have to say EIR.
Go to this link if you want and compare the pic of the EIR to your piece http://www.exoticwood.biz/woodchart.htm
Here's another source with about as extensive of a list of pics as you'll find anywhere. Or at least that I've personally found.
http://www.hobbithouseinc.com/personal/woodpics/indextotal.htm I use this one as my first goto for ID'ing any
exotic.
Hopes this helps. :)
Bill Hodge
PostPosted: Thu Apr 16, 2009 5:14 pm
Stephen
That's what I also thought when I saw the picture. I use a lot of morado for my fretboards so I'm used to seing it. That said, it still could be a lot of things...
Alain Moisan
(Now building just for fun!)
PostPosted: Thu Apr 16, 2009 6:19 pm
the photo is at best aghh but I can tell you it isn't BRW.
PostPosted: Thu Apr 16, 2009 7:02 pm
First name: John "jd"
City: Santa Barbara
Pau Ferro (Morado) is my guess.
I should point point out the Pau Ferro, BRW, and Claro Walnut are distictly different smelling.
Also please note that lots of people have allergic reactions to Pau Ferro dust.
-jd
PostPosted: Thu Apr 16, 2009 7:55 pm
Morado/pao ferro/maradillo/bolivian rosewood doesn't have open pores like that.
PostPosted: Thu Apr 16, 2009 8:22 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Did you pay an arm and a leg for that? I seen a set which the guy call "brazillian rosewood" but when I asked further question he said it was morado. If you paid brazillian rosewood price for that piece you got ripped off.
Typhoon Guitars
PostPosted: Thu Apr 16, 2009 9:52 pm
Last Name: Beaver
City: Lake Forest
It looks about 95% like the pauo ferro I use for binding wood.... Maybe even closer than that. But Mike is right Pauo Ferro is a pretty closed cell wood, even more so than EIR.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Apr 17, 2009 1:49 am
Are those pores open, Chuck? Sometimes pau ferro has dark close pores like that.
Ken Franklin
clumsy yet persistent
PostPosted: Fri Apr 17, 2009 7:27 am
Looks like EIR to me.
PostPosted: Fri Apr 17, 2009 8:52 am
First name: Chuck
Last Name: Gilbert
Thanks to all for the replies and apologies for the not so good photo. It seems very light in color for EIR, but the grain pattern is close. I am working on three EIR guitars now and the pores on the EIR seem to be a bit larger than on this wood, so Pauo Ferro might be possible. Also, the EIR I have (from LMI) is much darker than this wood. There are three boards of similar dimensions and they are all a close match in color and grain pattern. There are a lot of very pinkish purple hues in the wood so I'm not sure about the walnut comments though I've not built with walnut before.
The wood was given to my client by a friend of his who had it for over 10 years, so we have no idea as to the original cost of the wood. I've been commissioned to build an acoustic bass and a matching guitar for the gentleman. It should be a fun project.
Thanks again for all of your help.
Chuck
PostPosted: Fri Apr 17, 2009 9:21 am
In my shop we call wood of unknown type "tree wood", although you could make up a better name to tell the customer. You may never know what it is, but if you like its properties, build away, you know its at least ten years old.
Jordan Aceto
Ithaca, NY
PostPosted: Fri Apr 17, 2009 10:10 am
Country: Romania
It does look similar to EIR in many ways, but I don't think it is EIR. Brazilian, not a chance.
Build log
PostPosted: Fri Apr 17, 2009 12:44 pm
Last Name: Beaver
City: Lake Forest
The more I look, the more I say Pauo Ferro
Joe Beaver
Maker of Sawdust
PostPosted: Fri Apr 17, 2009 12:51 pm
Last Name: Cyr
City: Roseville
The colors and grain look like Morado AKA Pau Ferro AKA Bolivian rosewood to me.
--Steve
---Steve
PostPosted: Fri Apr 17, 2009 3:25 pm
Once again, Morado/pao ferro/maradillo/bolivian rosewood doesn't have open pores like that. At least not the last time I checked.
PostPosted: Fri Apr 17, 2009 5:30 pm
First name: Chuck
Last Name: Gilbert
Mike,
It may just be the photo because I sanded a piece through P220 this afternoon and it was very smooth with small pores. I also looked at a few pictures of Pauo Ferro on line and it looks very similar.
Chuck
PostPosted: Fri Apr 17, 2009 7:01 pm
Last Name: Hodge
Howdy Chuck,
I just looked at the Pau Ferro (aka. Santos Rosewood) on Hobbit House's site and I think that may indeed be what you have.
That ought to make for a nice instrument('s?) Enjoy building with it. :D
Bill Hodge
PostPosted: Fri Apr 17, 2009 8:25 pm
First name: Jake
Last Name: Archer
City: Kokomo
State: Indiana
I will say it does kinda remind me of pau ferro, the picture also kinda reminds me of some pictures of ovangkol that I've seen, that's an unlikely shot though.
Jake
~Make a joyful noise unto the Lord~
PostPosted: Fri Apr 17, 2009 8:31 pm
I have seen BRW of many different grain patterns and colors. What did it smell like when you sanded it. BRW usually has a fragrant flowery, some say chocolatey smell. Pau ferro has a spicy smell. EIR is much less pleasent.
It can be hard to tell some species when you are holding the board in your hand, much less from a picture.
PostPosted: Sat Apr 18, 2009 9:56 am
Here is a picture of a morado fretbaord blank I have. It has those little black closed pores Ken mentioned.
It's quite similar to Chuck's picture.
Alain Moisan
Users browsing this forum: pullshocks and 39 guests
cron
