It is currently Wed Aug 06, 2025 1:23 am
PostPosted: Sun May 31, 2009 5:33 am
http://www.mimf.com/nutcomp/index.htm is it realy neccessary? I have seen many guitars the players were happy with ,and not one had a nut that looked like this . thanks Jody
PostPosted: Sun May 31, 2009 6:09 am
not that i have any experience with this, but the nut could be compensated by setting it closer to the 1st fret than whats called for and cutting it back. wouldn't look so obvious that way.
But i'm sure that my ears would never pick up on the difference though.
Frank
PostPosted: Sun May 31, 2009 9:51 am
Last Name: Hodge
Looks to me like a radical attempt to "compensate" for poor setup and saddle placement. Among other things. beehive
Bill Hodge
PostPosted: Sun May 31, 2009 6:48 pm
That artical is 17 years old! I haven't seen anyone need that much nut comp. I've seen Mark Swansons compensated nut. He set the nut a little forward and routes back center of the string with something that looks like a 3/32" bit maybe. It looks pretty good nothing like the artical photo. That's just silly.
PostPosted: Mon Jun 01, 2009 10:35 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Funny thread title. :D
PostPosted: Mon Jun 01, 2009 10:45 am
Last Name: Garrish
Taylors all have some compensation at the nut. I believe they use 1/32", uniformly. It does make sense that, just like at the saddle, the 'best' nut compensation wouldn't be identical for all strings. Doolin wrote some stuff about it in his series of articles on intonation.
It is most certainly NOT 'compensating' for doing something else wrong. Guitars, by their design, don't intonate very well. For the most part, we're just very used to tuning out the dissonant sounds they make on some intervals.
Bob Garrish
PostPosted: Wed Jun 03, 2009 2:30 am
An interesting quote from a well known lute guru..."Compensation is for whimps!" :mrgreen:
PostPosted: Sat Jun 06, 2009 8:21 am
Well if you cut the front of the board at the zero fret the you already have 1/2 the fret slot nut compensation right?
PostPosted: Sat Jun 06, 2009 8:41 am
Exactly Chris .. thats how Taylor is getting their nut comp number ...
