It is currently Tue Aug 05, 2025 9:02 pm
 Post subject: Low fret dilemma
PostPosted: Mon Jun 01, 2009 9:38 am
For about a month I noticed some bad string buzz and/or choking of notes when playing on one certain fret.
It's a Stratocaster.
Strings high E to the 4th would buzz at the 7th fret, no where else.
I discovered the 7th fret was lower than the others.
So I files down the frets to even them out and recrowned the tops.
This cured 3 strings, it still buzzes for the 4th string at the 7th fret.
The 4th string has improved but not 100%.
My question is, should I go back and shave some more off all the frets or just look for something uneven around the 4th string area?
Thanks.
 Post subject: Re: Low fret dilemma
PostPosted: Tue Jun 02, 2009 6:43 am
you can just treat the problem areas by sanding them down slightly .. Jody
PostPosted: Tue Jun 02, 2009 8:23 am
Thanks, I'll try that.
PostPosted: Tue Jun 02, 2009 10:26 am
If you have a single high fret, you can bring it down level with the rest, but a low fret is a different issue. You'd need to bring all the other frets down to its level, or you'll just chase the buzz around. Need a large fret levelling beam, to glide accross the entire fretboard (to do it right).http://www.stewmac.com/shop/Fretting_supplies/Leveling/1/Fret_Fingerboard_Levelers/Pictures.html#details
PostPosted: Tue Jun 02, 2009 11:30 am
That's exactly what happened.
All frets were equal in height so they all had to come down.
After thinking about it some more I realized this and filed the rest down and everything is good.
PostPosted: Thu Jun 04, 2009 4:20 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Just replace the low fret with a new one and file it down to the level of the rest.
James
James W Bolan
Nashville Tennessee
Users browsing this forum: CraigG, FlyingFred and 40 guests
