It is currently Wed Aug 06, 2025 1:39 pm
 Post subject: Pore filling - top?
PostPosted: Thu Jun 18, 2009 12:41 pm
First name: Adam
Last Name: Yavner
City: Wylie
Zip/Postal Code: 75098
Hi all,
I have been looking at the info that is out there regarding pore filling, usually with epoxy or some kind of paste, but most instructions and tutorials I have seen seem to focus on the back/sides. Probably because it looks cooler in the pictures. I haven't seen any that talk about the top, but nothing has explicitly said not to do it.
Any thoughts?
adam
"Everyone wants to BE something, but nobody wants to BECOME something" - William Cumpiano
 Post subject: Re: Pore filling - top?
PostPosted: Thu Jun 18, 2009 12:52 pm
most top materials dont require filling.
PostPosted: Thu Jun 18, 2009 12:55 pm
First name: Adam
Last Name: Yavner
City: Wylie
So you just lacquer right onto the top? Any kind of sanding sealer or anything? Or is it desirable to have the grooves from the grain feelable (is that a word?) in the finish for the top?
Thanks!
PostPosted: Thu Jun 18, 2009 12:58 pm
First name: jack
the purpose of filling the back and sides is to fill 'open pored' wood ( such as mahogany or rosewood) to provide a smooth level surface over which your finish will be applied .
If you are using spruce as a top then it isn't necessary since it isn't open pored.
Some back and side woods, maple as an example, do not need pore filling either.
I have used paste wood filler for over 25 years, and have only recently switched over to Z-poxy..
In my opinion it is much easier to apply and looks better... doesn't have the sometimes 'muddy' appearance that paste wood filler sometimes does; addition to that, there is a great tutorial by Hesh Breakstone here on the OLF.. It would be well worth your time and attention to check it out.
best regards,
jack
PostPosted: Thu Jun 18, 2009 1:03 pm
First name: Adam
Last Name: Yavner
City: Wylie
Thanks, Jack! I actually checked that out and as it didn't mention the top, it caused me to wonder if it was left out because the process was the same, or because you aren't supposed to do it.
I think the consensus appears to be not to do it, so that's what i'll go with.
Thanks again,
adam
PostPosted: Thu Jun 18, 2009 1:25 pm
you can also use z-poxy on a figured top or other figured woods (maple bindings) to help pop the figure. You do a diluted thin wash coat.
PostPosted: Thu Jun 18, 2009 2:19 pm
Country: Romania
I've found that spruce straight from the sand paper can have too much texture to get a flat finish on, at least with very thin french polish. It might be especially bad with perfectly quartersawn wood (Shane... gaah ) which tends to have quite a texture after sanding. So you need to do a couple grain raising sessions with a damp cloth or with egg white. A bit later when it gets dry (do not flood the thing just barely damp the surface with a damp cloth or a fine brush and eggwhite) fine-sand the raised ridges. A second application and Bob is your uncle.
Build log
PostPosted: Thu Jun 18, 2009 2:32 pm
First name: Tom
Last Name: West
State: Nova Scotia
Adam: Have filled tops with a diluted coat of epoxy thined with alcohol. It helps to fill wooden rosettes and also lets you build faster with nitro. Have also finished with just the nitro and had success,drop filling any pores in the rosette. Dont think its too much to worry about and am sure either way will work out.
PostPosted: Thu Jun 18, 2009 2:50 pm
Personal opinion Spruce, redwood or Cedar tops should not be filled even with a diluted epoxy, though i have don it before. You just add to the damping of the tops responce when you fill or seal as it were with epoxy. Spruce I always size with egg whites. This will stiffen the outer fibers a good deal. it will aso cause those fibers to raise some after the sizing dries I lightly sand back with 220p and seal with shellac but I use shellac to seal everything prior to applying a sprayed finish. Shellac is the least dampening sealer or finish you can apply to the top.
PostPosted: Thu Jun 18, 2009 7:05 pm
First name: Christian
Last Name: Schmid
City: Edmonton
State: AB
Zip/Postal Code: T6E 1P9
I was wondering about the damping as well when using hardwood tops like mahogany, walnut, koa, or spanish cedar. Is there a pore filler that's preferable to the others with regards to damping (e.g., is pumice better than CA or epoxy)?
cheers, Christian
PostPosted: Fri Jun 19, 2009 5:43 am
I do not fill any spruce. You can use a sizing which egg whites are . Sanding sealer will do the job nicely , that is what it is designed for. No need to make it harder than it has to . If you are French Polishing , the wet sanding should get you level. Use 320 and go across the grain. That is a trick I learned from Frank Ford. This levels the top very well.
PostPosted: Sun Jun 21, 2009 10:46 am
I personally like it when the top finish is ridgy with the hard winter growth, i think it looks nice, and it is an indication that the finish is probably not too thick.
Jordan Aceto
Ithaca, NY
PostPosted: Sun Jun 21, 2009 11:07 am
First name: Ron
Last Name: Senf
City: Muskegon
Zip/Postal Code: 49445
Hi Adam. I used a thin coat of diluted zpoxy (50%) denatured alcohol on my last two tops because I wanted to add a little amber tint to the top. Otherwise, I've been using clear shellac as a sealer coat. BTW, are you the fellow that bought my HD28 a couple years back?
PostPosted: Sun Jun 21, 2009 2:31 pm
First name: Adam
Last Name: Yavner
City: Wylie
Hey Ron,
Yep that's me and I still can't believe my luck every time I open the case. Thanks!
adam
Users browsing this forum: Melt in the Sun, ptourin and 13 guests
