It is currently Thu Aug 07, 2025 10:06 am
 Post subject: Countersinking
PostPosted: Tue Jul 14, 2009 10:38 am
I'm thinking of doing a bolt-on neck on an SJ that I'm building. The problem is that I've already built the body and did not pre-drill or countersink the heel block. I don't have any problem with drilling the bolt holes, but would like any advice on countersinking the block for the washers & nuts. Thanks in advance.
Jay
 Post subject: Re: Countersinking
PostPosted: Tue Jul 14, 2009 10:50 am
Aircraft tool suppliers carry "reverse spotfacers"
Here's one link. www.theyardstore.com
Do a search for "spotfacer" and you'll find the reverse ones. Get a shaft the same diameter as your hole and a spotfacer the diameter of your washers. They are good for putting an end jack in a guitar with a thick tailblock too.
TJK
PostPosted: Tue Jul 14, 2009 3:34 pm
First name: Tom
Last Name: West
State: Nova Scotia
Why do you want to countersink? Here we just use hardware from Lee Valley,flatheaded bolts with about a 5/8" round head made to be tightened by an allen key. They have a bronze color to them and I think look classy.Also gives folks in the future a heads up to how the neck comes off.
PostPosted: Tue Jul 14, 2009 4:35 pm
First name: Tom
Last Name: West
State: Nova Scotia
Have reread your post and now I gather you are using lag bolts....????? Think that most folks use inserts or barrel nuts with headed bolts...?
PostPosted: Tue Jul 14, 2009 5:44 pm
He's likely using hanger bolts. The type with one end with wood threads and the other with UNC threads.
PostPosted: Tue Jul 14, 2009 5:47 pm
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
theres an article called spanish heel neck reset an impossible job ?
Frank Ford talks you through he uses a bit and reverses the cut on it
i did something simmilar but instead of using the bit he used im using a
a normal contersink bit (sorry dont know the name of it )
but its the flat ones with the spear head shape on the top
i basically squared off the bottom the same way as the other side
cut into the taper with a rough bastard file till its the same radius as the bit
duplicate the cut on the new cutting side and i always make sure its sharp
PostPosted: Wed Jul 15, 2009 3:17 am
Yes, Darrel I'm planning on using hanger bolts, and, Terence, the reverse spotfacer is exactly what I'm looking for. Thanks all for your suggestions.
michael propsom
www.propsomguitars.com
Users browsing this forum: DennisK, Ken Lewis, ptourin and 17 guests
