It is currently Wed Jul 30, 2025 12:53 am
PostPosted: Tue Sep 20, 2005 11:07 pm
I just bought a new buffing mandrel. This new one is larger than my old
one, so I need to replace my buffs. I need 10" dia. with a 1" hole. I guess
canton flannel is probably best, but I'm open to suggestions. I can't seem
to find a supplier, so if anyone can point me in the right direction, I'd be
most appreciative. Also, do you think it would be advisable to go to a 12"
buff? I think a 1" shaft should handle that ok.
Craig
PostPosted: Tue Sep 20, 2005 11:59 pm
Craig, go with at minimum a 12" wheel, 14" if you can find them. I don't know a supplier off the top of my head, but somebody here will. Did you try Parma or Grizzly?
PostPosted: Wed Sep 21, 2005 12:40 am
Caswell has a large selection of buffing wheels...often priced at 2 for 1.
PostPosted: Wed Sep 21, 2005 1:21 am
Here is the link to Caswell. As JJ mentioned, they usually have good sales.
PostPosted: Wed Sep 21, 2005 1:28 am
I use the Caswell 14" Canton Flannel. They are great.
PostPosted: Wed Sep 21, 2005 2:04 am
Brock,
Do you use just one or do you put two together as the Stew-mac set-up suggests?
Oh ya! What compounds do you use?
ShaneShane Neifer38616.4624537037
PostPosted: Wed Sep 21, 2005 2:05 am
I have 2 together. They are pretty thin to use 1 at a time.
PostPosted: Wed Sep 21, 2005 2:21 am
And what compounds do you use?
Thanks Brock
PostPosted: Wed Sep 21, 2005 3:01 am
I have the menzerna (sp) compounds from course through very fine. I got them at Grizzly. I think Stewmac carries all of them too. Depending on the finish, how far I have sanded it, etc. I start buffing with different compunds.
PostPosted: Wed Sep 21, 2005 3:53 am
Thanks everyone. Since I posted my inquiry I ran across Caswell doing a
Google search. Looks like that's the place. I'll try the 14" canton flannel
buffs. Maybe I'll shine my shoes while I'm at it! Thanks again.
Craig
PostPosted: Wed Sep 21, 2005 5:05 am
Thanks for the info Brock, I just ordered one (2 actually with the 1 free) and a wheel rake. Good source.
PostPosted: Wed Sep 21, 2005 2:39 pm
Craig, another place you might consider is http://www.jestcoproducts.com/
They will make-up buffing wheels to your specifications i.e. diameter, thickness and arbor size if you can't find what you are looking for on their website.Anthony Z38616.9874305556
PostPosted: Wed Sep 21, 2005 2:49 pm
doug
you do realize that you need a different set of buffs for each grade of buffing compound used?
PostPosted: Wed Sep 21, 2005 5:13 pm
Yeah, I have 3 other buffs. But thanks for thinking of me. I also have the medium and fine menzerma sticks.
PostPosted: Wed Sep 21, 2005 9:11 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Brock,
Do you ever use the cotton wheels?
PostPosted: Wed Sep 21, 2005 10:56 pm
I use the 14" canton flannel buffs
PostPosted: Thu Sep 22, 2005 2:20 am
Anyone tried the denim wheels Caswell claims them to be as soft as canton but much more durable
