It is currently Sat Aug 09, 2025 4:00 pm
PostPosted: Sun Aug 02, 2009 3:14 pm
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
SO the intonation on my first uke is horrible the strings are WAY too high from nut to saddle. Whats the best way to fix this? I figure if I take off the nut and sand the bottom slightly that should bring the nut side down(thats the really high side) but what about the saddle? do I sand the saddle (not very larg)e or deepen the slot slightly? Should I just do the nut side and see if the saddle side comes down enough from that?
Thanks all
Zac
Anchorage Alaska
Finshed my 1st! See #1 here
PostPosted: Sun Aug 02, 2009 5:04 pm
How high is your saddle above your bridge Zac? If you have room to knock an 1/8" off the bottom of the saddle, it will lower your action at the 12th fret by about 3/32" because of the short scale. As far as the nut goes; fret a string at the third fret. There should be a whisker of air between the string and the first fret. If it's close, just file the slots a little deeper to bring the strings down and then file the top of the nut down if the slots are excessively deep. If it's a 1/16" or more, then sanding the excess off the bottom of the nut is what I would do before final filing. Wait for another opinion, but this is what I would do assuming you bridge is not too thick or your neck angle too far out. In those cases, you'd be looking at thinning the bridge or resetting the neck.
Users browsing this forum: TimAllen and 43 guests
